help with ecotec swap!!! - Performance Forum
Sunday, August 19, 2007 7:57 AM
ok so here is the run down
I went from a 2000 z24 sunfire convertible engine and I put in an 2004 2.2 ecotec cavalier engine
everthing was transfered over and Ieverthing is installed and fits.
heres the problem
when I go to crank it over it doesn't start. it has spark and it has to do somthing with the fuel because when I spray a little starter fluid into the throttle body it starts. andthe injectors are good and it has proper fuel pressure
it has to be somthing electrical that is not allowign the injectors to open.
if anybody has any advice let me know thanks
Re: help with ecotec swap!!!
Sunday, August 19, 2007 8:03 AM
did you do the pass lock re learn??
Sunday, August 19, 2007 8:06 AM
hmm I will try that that might be it I did even think about that.
Sunday, August 19, 2007 8:23 AM
your think that the crank position variation relearn needs to be done? I have started the 30 min passlock relearn on it. hopefully that fixes it.
Sunday, August 19, 2007 8:33 AM
95% chance it's the passlock.
Sunday, August 19, 2007 11:47 AM
My car did the same thing when i did the ecotec swap.Do the passlock relarn and you will be good.This link will tell you how to do it.
http://www.j-body.org/faq//98/
Sunday, August 19, 2007 12:35 PM
yea that was it. Thanks guys for all your help
