I'm currently in the process of swapping an L61 for the LD9 that's currently installed in my car. It's becoming easier to find the
L61 out of a Cobalt/Ion than it is a J-body, and that's what I purchased when I bought my motor. I thought I would post up the
differences that I have run into during this swap.
I'm ONLY going to put in information about the differences between the J-body Eco and non-Jbody Eco. There are lots of other threads
about the actual swap, so please do a search for those to figure out what other parts you might need.
the actual motor:
-Due to a difference in the reluctor wheel in some of the Eco motors, if you have to get one out of a Cobalt/Ion, stick to '03-'06.
L61's started using a 58x reluctor wheel setup sometime in '06, which is incompatible with our ECU's. Also, all other Eco motors
(LSJ, LE5) use the 58x, so don't think you're going to drop a 2.4 or supercharged 2.0 Eco into your J-body, unless you plan on
running a full standalone engine management setup.
mounting:
-The Cobalt/Ion uses a completely different mounting setup. You'll need a new top mount, and the bracket that bolts to the motor that
the top mount bolts to.
-You'll also need the lower mount bracket from an Eco-powered J-body that bolts to the oil pan.
oiling:
-The Ion/Cobalt uses a different mounting setup, so the oil pan is different. You'll need a J-body Eco oil pan.
-You'll also need a J-body Eco dipstick tube.
intake/exhaust:
-Check the throttle body that's installed on the engine you buy, and verify it's activated by cable. If not, you'll need on of those.
-I've yet to see anyone retain the stock exhaust manifold during their swap. You'll have to check on your own to make sure this would be
compatible with the stock J-body exhaust if you still have it.
transmission:
-The transmission in the Cobalt/Ion uses different mounting points. Count on buying an '02 Cavalier LS Sport, or '03+ J-body transmission.
-Also, you might need the J-body trans mounts as well, depending on the setup you have, and the one you are going to install.
fuel system:
-I know that the Ion L61 that I bought was setup for a returnless fuel system, meaning there isn't a second fuel line coming out of the
fuel rail going back to the tank. Of course, this all has to be changed. You'll need the fuel rail and the fuel lines (from the rail to back to
where the connections are by the firewall) from an Eco J-body.
-The injectors and injector harness from the Cobalt/Ion motor should work.
power steering:
-I know that the Ion's use an electric steering setup, so the power steering pump is not installed on the motor. You'll need a power steering
pump. The '00+ pumps should work.
-Also, the hex drive machined into the intake cam on the J-body Eco is not on the Ion Eco either, so you'll need at least the intake cam.
-Here's the tools that are needed and/or helpful for the cam swap:
Ecotec Cam Swap tool (Kent-Moore J-43655)
Ft/lb torque wrench
In/lb torque wrench
Torque angle meter
Also, the cam sprocket bolts are torque-to-yield meaning they are not reuseable. You'll have to hit up the dealership for these. They ran me
about $15 a piece.
Desert Tuners
