ive been looking around for some good power adders... superchargers or turbochargers... anyone have any good ideas? links? pics? lets say if you had 5k to play with... what would you go for? help plz!!!!!!!!!!!!!
"Z24 Dustbunny"
If i had 5k to play with, I would upgrade my nitrous system, get all the accessories, forge my internals, top half, bottom half, & do all necessary fuel upgrades, then spray the $hit out of it, but hey thats me... i'm a bottle jocky
http://www.motortopia.com/cavyfreak442/cars
Best ET to Date: 14.251 @ 98.51 mph. 13's or Bust Baby!
no forced inducion? .. can you list your setup????
01 cav 2.4l tho ... umm so if i did that.. wouldnt have a prob with the iron block??
"Z24 Dustbunny"
srry looked up sticky on turbo.. but superchargers? anything to advance the oooo 50hp from the kit? pulleys n what not?
"Z24 Dustbunny"
Yes if you do go supercharger you can upgrade the pully to a smaller one to increase psi, also supporting mods like a header, exhaust, etc. Help with the power a supercharger gives. I'm sure theres a faq somewhere.... just too tired to look atm, lol...
currently i have a nx wet kit set at 75 hp spray
warm air intake
lower engine mount
short throw shifter
transmission mounts goin in in next few days
spinnin through 1st my best et is a 14.2 atm, soon gonna drop a lot more
Being that your car is an '01, if you've got $5K to play with, I'd say go with the GM Supercharger since you can use the GM reflash on it, then get HPTuners for fine tuning, and build the block. Even guessing on the high side you should still have at least $1K left at that point. You could get a new pulley and run higher boost with the S/C and see some pretty decent power, and it should be solid as a rock with the built bottom end. Hell, if you find you're still looking for a bit extra, with a built block and your remaining money, you could easily spray a 75-100 shot on top of the charger and, IMO, have quite a monster. That's what I'd probably do.
Click me for a link for the GM Supercharger...
Turbo would be nice because honestly you can get more power from a turbo, however you would also have to customize your own kit and have the downpipe and such custom welded. If you could do that yourself, or could find someone who would, and you're after really big numbers (seems with the S/C and nitrous you'd probably top out around 350 whp), that would be the way to go. Depending on what kind of deals you find, turbo could be about the same cost as S/C, or could be a bit less...or a lot more (you can get the GM 'charger shipped from crateenginedepot.com for ~$1700 IIRC).
Regardless of what you do (turbo, S/C, or nitrous), I'd say your first step should be to build yourself a nice bulletproof block - pistons, rods, bearings, EVERYTHING. If by saying "if you had 5K to play with" you mean that's what you actually have available, pick up a spare block and the parts and have it built (or build it yourself if you can), and don't go cheap. You should still have plenty left over for whichever route you go. Do it right the first time and you'll never look back, I'm sure.
Marcus Williams wrote:Being that your car is an '01, if you've got $5K to play with, I'd say go with the GM Supercharger since you can use the GM reflash on it, then get HPTuners for fine tuning, and build the block. Even guessing on the high side you should still have at least $1K left at that point. You could get a new pulley and run higher boost with the S/C and see some pretty decent power, and it should be solid as a rock with the built bottom end. Hell, if you find you're still looking for a bit extra, with a built block and your remaining money, you could easily spray a 75-100 shot on top of the charger and, IMO, have quite a monster. That's what I'd probably do.
Exactly, make it that you will never have a problem with holding the power you wanna put down, then you can go with whatever you want to make whatever power you want, and from there the sky's the limit =)
