Ok, i have a sunbird.. and i am planning on deburring the block, and bottom end tomarrow.. and i have read up alot, and just think i would feel better asking you guys as well.. from what i have read, it says i can use 400-600 grit sandpaper?? also.. is deburring basically just getting rid of all the sharp edges?? I was also wanting to polish the rods and pistons... what would be the process on that?? from what i have read, i got the deburring right.. and as far as pistons.. i have read just round off the "crown" of it.. the top anyway... but how do i get the polished finish on them?? i hope you guys can help me.. thanks in advance to all
"Hondas are like tampons, every pussy has one!!!"
You are correct about deburring. It refers to smoothing out any sharp edges.
As far as polishing the rods...WHY? I can understand why you may want the tops of the pistons to a polished finish, but unless you are running a clear plastic block with clear oil, I really don't see the point of going through the work of polishing the rods, when it will do nothing for performance, reliability or aesthetics.
"Youth in Asia"...I don't see anything wrong with that.
alright, thanks...
and about polishing pistons and rods, i heard that if you do it, it will keep temps. down.... and also, someone said it would be a good idea to debeam, deburr, polish and shot peen the rods to run more boost on them...
ok, i attempted some of it today... i used 100 grit and 150 grit sandpaper, as thats all i had... ill post pics tomarrow if you could tell me if it looks ok?? i think its fine.. but just wanna see from someone that would know better.. thanks..
Does this look ok?? also... is there anything else i could do besides just casting flaws?? like what edges are there to round off... im not sure which ones are ok to do... and a guy also told me that if you sand down the walls of the block.. it would help too.. can anyone confirm this? thanks in advance for help...
