hello everyone , im looking to boost my 96 z24 2.4l, starting maybe with 10lbs of boost , i want to know first if a could use my stock injectors.. what im basically want to know is how many cc's are my stock injectors and what is the impedance of those please ..
can i use injectors from a 3.1 z24 ??
2nd question .. can i use my stock fuel pump ?? which one can i use please
thanks
I believe they are 252cc injectors and low impedance...I dont know about the 3.1 injectors but I wouldnt imagine they have many more ccs. My guess is with 10lbs of boost you would want 370-450cc injectors. I think you could use ford brown top 35# injectors the ones im looking at are low impedence....they might fit without modification. I know the green tops do but they are high imepance...I think I remeber people on here talking about using brown tops. Hope that helps and if im wrong sombody please correct me.
thanks for all the info,, but what about the fuel pump....... can i use the same one or i need something different
thanks
were i could search for those ford brown top injectors ?
Glad I can help. Im not sure about the fuel pump...I have seen people post on here about a blazer fuel pump swap. Try searching on google or ebay for the brown tops but like I said above im not sure if they are direct bolt on, I am sure you will need new clips(harnesses but they call them clips if you didnt already know).
can i use high impedance injectors with my car or they have to be low impedance ?????
thanks
