ok so i put my wideband back in the car and im using the wideband to send the 5v signal to my gauge and the 1v narrowband to the stock pcm
My problem is the ground wire, there are 4 wires on the o2 sensor, the two white are fine thats the heater circuit i have that taken care of with a resistor, the gray is the signal wire, i have the narrowband signal here and thats all good
now on the o2 sensor there is a black wire, can i ground my wideband to this?
heres a pic of the control box i made which holds the resistors
what year and engine is this for? how many wires was the stock o2? what exactly are you trying to ground here, the control box for the wideband?
I'm lost....
All I did was plug my PLX narrow band output to my sensors signal (yes, I know mine is a 2 wire, yours a 4 wire)...... HPT makes short work of any heater/slow responce codes you might get.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
i thought i read somewhere that the stock o2 reads 0-1.25v, not 0-1v?
All Gm 4 wire 02s are the same pretty much, I figured it out, I did use the ground to hook the wideband controller and it works, I have to confirm by driving the car and reading the mv in HP tuners
Id rather have it work properly than just turn off codes in Hp tuners
that ground wire goes to the body of the o2 sensor, which is tightly threaded into your exhaust. so you are in reality grounding your wide band to the exhaust, which should give you plenty ample ground to run your wideband
Rodimus Prime wrote:Id rather have it work properly than just turn off codes in Hp tuners
How is it working properly, if your using resistors to trick it? I dont get it? All the ECM needs to see is the signal, which PLX provides..... the rest is just used to either heat the sensor (which the PLX setup does for its own sensor, and your wiring in a resistor to similate, when one click of the mouse can turn it off with HPT), or to moniter the sensors condition, which your tricking. In the 1 wire setup, the ground is the exhaust. In the 2/4 wire, the ECM provides a ground so that it can monitor the sensors responce time.
So again, I dont get it? Seems like your doing work you could take care of with a few clicks of a mouse..... Now in Pre-HPT days, this would be pretty good to have..... kinda like the VSS Switch
I know, I know..... not everyone has HPT, but they should
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
SpeedRacerZ wrote: I know, I know..... not everyone has HPT, but they should
x1000000000000000000000000000000000000000000000000000000000000000000000
well it didnt work anyway, the wideband controller isnt putting out the narrowband signal properly so I'll just have to do what i did before and have a seperate bung added
