after looking around i keep getting mixed reviews on what size im supposed to be using, i also have chris fontana's adaptor flange as well so keep that in mind.
i have found that i need M8x1.25 65mm studs on 1 site
then on another im supposed to run 5 M8x1.25 45mm long bolts and 2 M8x1.25 60mm long studs
anyone able to give me some insight
thanks
I used 5 45mm bolts and 2 65mm studs, both M8x1.25. the studs you'll want longer than 60mm just to be sure. They're not gonna hit anything if you go a little longer than necessary.
you are running the adaptor flange as well? i checked your registry but couldnt find out
the 2 studs get put in the bottom 2 holes of the head as well?
Or you can just email chris your self and just buy the bolts off him thats what i did.CUSTOMZ24CONV@aol.com is his email addy.
ill try him then. i cant seem to find them and those bolts are the only thing preventing me from doing this
Yeah the studs go in the bottom 2 holes on the head, where you remove the stock ones from. They are kind of a PITA to track down, but I got em from NAPA.
Napa was the only place i didnt check. LOL
Hey 99redz i would try that place cuz i just got my package from cris fontona and there was no bolts in the envelope.The side of the enxelope was ripped open cuz of his poor packaging and now he is avoiding me and wont send me my money back!So your better off buying them from napa then have to deal with him.
Those are all M8 x 1.25.... so, yes. You could also get them from a hardware store.
"Youth in Asia"...I don't see anything wrong with that.
does the 086 head use the same M8 X 1.25 bolts/studs for the manifolds?
