today i installed a 2.3 throttle body on my car. everything is working great except for one problem. I went to give it some gas from inside the car and my gas pedal is just dead. it sticks to the floor with no return and does nothing. if i manually move the throttlebody it works fine. I was thinking about double checking the throttle cable to see if its hooked up right. there was an aftermarket cruise that i took out today also. that had a seperate cable hooked up to the old throttle body. is there anything as far as wiring that could be the problem from the cruise. I'm just trying to get some ideas before i go to fix it tommorrow.
well i decided to go double check everything and sure enough, the cable was unhooked. I must have forgot it or something.
I hate you. thanks for helping ron
I had that problem it was just rubbing against the throttle cable metal piece and it got stuck exactly at wot.
____________________________
Dracula called, and he's coming tonight!
