My Ecotec Compression Test... - Performance Forum
Saturday, March 10, 2007 9:32 AM
Did one last night and i got #1-#4, 190-200-195-175 Does this sound normal? 60K miles
Re: My Ecotec Compression Test...
Saturday, March 10, 2007 10:05 AM
1-3 sounds good, 4 seems a little low.
Saturday, March 10, 2007 10:30 AM
thats what i thought and i can smell a hint of oil from the exhaust too. someone said check valve cover gasket. but there was a little oil on the #1 plug so i dunno whats going on.
Saturday, March 10, 2007 11:17 AM
They should all be within 10% of the highest number. #4 is 25PSI low vs. the 20PSI the spec allows. Not really low but I would try a Leakdown Test and see where exactly it's leaking.
5K PB: 24:50
10K PB: 54:26
Saturday, March 10, 2007 11:27 AM
Team Vision Racing (aka hypsy) wrote:They should all be within 10% of the highest number. #4 is 25PSI low vs. the 20PSI the spec allows. Not really low but I would try a Leakdown Test and see where exactly it's leaking.
I could not remember the exact %, so I did not want to say. I agree with a leakdown test as well.
Saturday, March 10, 2007 11:29 AM
ive got the leak down tester as well. ill have my dad help me with that.
Saturday, March 10, 2007 2:59 PM
It's 10-15% according to the manual. I always go by the 10% though.
5K PB: 24:50
10K PB: 54:26
Sunday, March 11, 2007 5:30 AM
may want to try cylinder 4 on more time, you have to make sure you crank it over the same amount of time on every cyliinder, you may have been short one compression stroke.
Sunday, March 11, 2007 10:15 AM
how long am i supposed to do it for? i held the key for 5 seconds, my dad said i really only need to hold it for 3. ill try them again later.
Sunday, March 11, 2007 2:52 PM
You don't count seconds you count compressions strokes. Pull all the plugs out and watch the gauge as you cank the car. You'll see the needle move with each compression stroke. You want 5 strokes for an accurate reading.
5K PB: 24:50
10K PB: 54:26
Sunday, March 11, 2007 4:07 PM
My LD9 that is in my car right now is 43psi below the others 3. You can smell her burning the oil.
hypsy is correct.
Thursday, April 21, 2011 9:48 PM
gonna just ask here instead of making a new thread. What do you guys think compression should be on a 110k mile eco. Also, would oil viscosity make a difference in compression?
Thursday, April 21, 2011 11:25 PM
Holy ancient thread Batman!!! For the sake of relevancy, oil viscosity will have no bearing on compression readings. As far as compression readings on a high-mileage engine, I generally go with no less than 75% of the factory specs, and no more than 10% variance between cylinders.
Friday, April 22, 2011 12:00 AM
so 160 155 165 160 wouldnt be like OMG need a new motor bad?
anything special to a compression test on a supercharged motor. anything about the bypass valve position I need to know. I read on here in a few threads that 185-225 is good, and in other threads that as low as 147 is good...
Friday, April 22, 2011 1:10 PM
Those numbers are fine was it cold or warm compression test its supposed to be warm so numbers will come up more if it was done cold.
Saturday, April 23, 2011 7:45 AM
if your smellin oil it could be your intake manifold the 04s have a TSB for an over sized PCV hole GM recommends replacing the manifold my buddy is dealin with his right now he works at the dealer
JBO since July 30, 2001
Sunday, April 24, 2011 12:19 AM
Seafoam piston soak over night drive it then retest
see ya!
Monday, April 25, 2011 10:50 PM
After 30k miles boosted at 100k total miles on my cav the numbers were 210-209-183-208, completely stock engine, never even had the valve cover off, last I heard its still running around in Ohio with 130k+ on it
Thursday, April 28, 2011 1:43 PM
novaracer wrote:Seafoam piston soak over night drive it then retest
wtf is up with this Seafoam I'm hearing so much about all the sudden...
Buddy Club Ecotec Cavalier
* More to come *
Thursday, April 28, 2011 5:29 PM
Look it up. Zmax piston soak works as well but it cost too much. It does break down carbon
see ya!
Thursday, May 05, 2011 3:36 PM
as long as its not like mine... 190-184-200-70 LOL
13.22 @ 105.2
