Basically, what I'm seeing from the threads on here is that I have (2) options: a higher-volume Mullen (sp?) pump or, well, stock. Is this pretty much the case, guys?
My motor said "Peace Out!" (last season) because my oil pump seized up tighter than a frog's a$$ in cold water. This season I'll be pushing almost double the PSI (up to 12) and a 50'ish shot of nitrous. It PAINS me to put a stock pump back in (even if I have it on the loose side of spec) but my time frame is so tight I'm not sure if I'll have time to "play" with diff. pumps that "might" fit. Thanks in advance for any input, guys!
could try dry sump...would open you to more options
MadJack wrote:The '90-'93 LN2 oil pump is a direct bolt on replacement. It supplies approximately 10% more volume and has a 60psi relief spring. This is the best pump for anything but a max effort race motor. There is also a high volume pump, that supplies 25% more volume than stock, but would be over kill and uses up more power to move the volume of oil it's moving.
Adler wrote:Melling makes a high volume pump that will fit the newer 2.2s. The pump is actually listed for a 90-93ish 2.2. The stock early 90's 2.2 oil pumps flowed more volume than the newer 2.2 pumps anyways. The high volume pump that Melling sells suppose to flow 25% more than the stock early 1990 pumps.
Edited 1 time(s). Last edited Thursday, March 08, 2007 11:33 AM
