once and for all are the 2.3 towers a direct fit to the 2.4 for the secret cams swap?
a spent a few hours with my pal the sdearch button first but no clear awnser
2.3 towers will fit on a 2.4 head but on the 2.3 intake housing there is no spot for a cam sensor , plus with the secret cam swap you use your 2.4 towers
R.I.P. Brian Klocke, you will never be forgotten
The secret cam swap is designed so that you don't need to use 2.3L cam towers. The biggest obstacle with using the 2.3L cam towers would be swapping over to the 2.3L power steering pump. Now that there is the MSD cam sync, the grind for the Cam position sensor is no longer necessary.
"Youth in Asia"...I don't see anything wrong with that.
2.3 LO Cam towers = direct bolt on for the most part, except the cam sensor issue.
My Cav
I give up...
make sure you get the 1995 2.3 intake cam vin "D" (so you can keep your stock power steering pump)
and they both fit in your stock housings, you just need the cams. :cheers
95' towers are crap...The lifters are 33mm too.... I checked
seeing that he only needs the 33mm lifters, he's fine....... Secret cams, not HO...... They fit in the stock 2.4 housings, dont need 2.3....... BUT the housings that come with the secret cams (95 intake, 90-94 exhaust) WILL fit on the 2.4 w/o any problems.
love when people dont read whats being asked...... thats why there is always 50 posts on the same subject.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
No sh*t...I answered his question in my first post...I was going on 40 hrs of no sleep and misread what Garrett wrote. I was just stating that the 95' are no different in size compared to the 2.4 housings.
I am curious how you know my name.. and the correct spelling, lol
