backpressure and resonators - Performance Forum
Saturday, November 11, 2006 3:25 PM
getting my mandrel exhaust done next week and wondering if a resonator acts as backpressure at all along with making the tone quieter because im nervous about getting 2.5 catback and losing power because my dynamax muffler is only like 12" long i got so if the resonator will help with backpressure i might get a 12 or 18" one. thanks.
Re: backpressure and resonators
Saturday, November 11, 2006 3:46 PM
you wont lose any power by adding a resonator, you worry WAY too much about miniscule things. a 2.5" exhaust is plenty big and there isnt too much you can do to really restrict it enough to notice a big difference if any at all.
_______________________
** Flat Broke Racing Inc.**
Saturday, November 11, 2006 4:48 PM
im worried about losing power because 2.5 may be too big, wondering would a resonator make me have more backpressure so i can keep/gain some power. thanks again.
Saturday, November 11, 2006 5:00 PM
backpressure:exhaust velocity :: centrifugal:centripetal
(for the people going )
Backpressure is to exhaust velocity as centrifugal is to centripetal (centrifugal is fictitious -- it doesn't exist)
Mainly your question is "how do I increase exhaust velocity"
If your exhaust system is properly sized for the amount of exhaust gases being expelled, the resonator won't really change the exhaust velocity.
There was a thread discussing "is it backpressure or exhaust velocity"
Saturday, November 11, 2006 6:02 PM
well i know when i got the 2.25 put on like 2 years ago i took it for a spin in the parking lot with no muffler and the thing had no go.
Saturday, November 11, 2006 6:17 PM
Here's what I've noticed since I put the 2.25 on
Lower RPM - butt dyno says power loss up to 2500 rpm
Above RPM - butt dyno notices gain on my N/A engine
Saturday, November 11, 2006 7:19 PM
BOOSTED wrote:im worried about losing power because 2.5 may be too big, wondering would a resonator make me have more backpressure so i can keep/gain some power. thanks again.
you wont have any problems with a 2.5" exhaust, its on the big side unless you have some pretty decent mods done but its great for top end power...
Saturday, November 11, 2006 11:16 PM
I know this will get argued but im almost postive that backpressure on any motor is a bad thing.
Sunday, November 12, 2006 12:43 AM
USJDM.....GOT YA B!TCH! wrote:I know this will get argued but im almost postive that backpressure on any motor is a bad thing.
Correct
Event wrote:basically the less backpressure and the higher exhaust velocity...the better.
in a perfect world, near zero backpressure and super high velocity would be ideal...aka the scavenging effect would be at its utmost, but thats in a near lab non variable environment, hence, nearly impossible in the real world.
so where as, there will ALWAYS be some backpressure as its inevitable, the less you have, the less work the engine has to do to pump and blow out exhaust. the less the engine has to struggle the higher the volumetric efficiency.
the statement, engines need some backpressure to work, or for it to be good.... completely FALSE. i thought the same till i started reading alot of tech and theory books on nothing but exhaust and intake.
Sunday, November 12, 2006 7:19 AM
ugh, boosted i know what you mean.it seems that on these cars that if you just cut the cat off that you'll loose power because.... ding ding ding you have less backpressure to help promote the scavaging effect. Backpressure on a N/A motor is actually pretty good cause it helps with things like this. Some cars don't like backpressure as much as ours do. Like the new hemi trucks, I know that they don't like backpressure much at all, so cutting off the cats helps them more than it's going to help us on our 4cy cars. It's just the nature of the motor. So instead of pulling the next exhaust pulse out of the cyl.(scavaging) you just kinda dump it into the exhaust and let it float on its way.
Are you doing this for a boosted application? If not go out and buy a high flow cat. It'll make the car sound great and help you not loose much powerin your low end. 2.5 is kinda big for n/a thats why i'm thinking your going with boost. if you are just do what you were going to do, if not, just get a high flow, or get 2.25, or just get a res. or you'll prob be a little raspy with such a large diameter exhaust piping.
I just woke up and threw this together so there are many points that someone could pick at and argue with that I didn't feel like filling out cause this is already kinda long.
Sunday, November 12, 2006 2:22 PM
By his sig, he is boosted. Meaning 2.5 should be ideal.
Sunday, November 12, 2006 2:30 PM
tampaGT wrote:ugh, boosted i know what you mean.it seems that on these cars that if you just cut the cat off that you'll loose power because.... ding ding ding you have less backpressure to help promote the scavaging effect. Backpressure on a N/A motor is actually pretty good cause it helps with things like this. Some cars don't like backpressure as much as ours do. Like the new hemi trucks, I know that they don't like backpressure much at all, so cutting off the cats helps them more than it's going to help us on our 4cy cars. It's just the nature of the motor. So instead of pulling the next exhaust pulse out of the cyl.(scavaging) you just kinda dump it into the exhaust and let it float on its way.
please stop making jbody folks look like a bunch of retards, you in all honesty should really go back to reading instead of posting and throwing in your
do you honestly have any proof that " on these cars they love backpressure "? because i would sure love to see it... maybe the drinking water is alittle different down where you are or something because around these parts there is proof of some noticable gain from uncapping the exhaust.
Sunday, November 12, 2006 3:09 PM
my car has the po420 (low catalyst efficiency) code. I was considering replacing the cat, should i get one of those high flow cats as well ? are they near the same price as a factory one? I'm not worried about emmisions or anything, i'm also considering an aftermarket header pipe. can you guys advise me on what to get ? thanks.
2001 2 door five speed 122k.
custom steering linkage pop
2000 s10 (THE WORKS)
Sunday, November 12, 2006 5:02 PM
thanks guys,what exactly is the deal with some people using both 2.25 and 2.5 in their setups? im looking for the best setup i can do with keeping all around power at the same time, ill be going with a hollow cat and a 12" dynamax muffler. I might be getting my downpipe redone as well, i think the pacesetter one is 2.25", so any recommendations on the downpipe size going with the catback will help as well. Also would there be ANY power loss from running duals as oppose to just a single exhaust? thanks again.
Sunday, November 12, 2006 5:10 PM
we dont loose power when you cut the cat off because of backpressure but rather because your completely @!#$ w/ your AFR's which makes the car run pig rich, which makes the car run limp, which makes it seem slower.
Sunday, November 12, 2006 5:19 PM
USJDM.....GOT YA B!TCH! wrote:we dont loose power when you cut the cat off because of backpressure but rather because your completely @!#$ w/ your AFR's which makes the car run pig rich, which makes the car run limp, which makes it seem slower.
mines just gutted, so just the shells there
Sunday, November 12, 2006 9:47 PM
actually i havent seen one go into "limp" mode yet when removing the cat. and as for the deal with some people using 2.25" and 2.5" exhaust in they're systems imo is thats just what they want, an exhaust system can only flow as good as the restrictions it has. I wouldnt remove the cat. converter completely unless you have HP tuners to disable the codes. as i said the cats dont restrict flow too much unless they're clogged.
Guys your really dragging this thread on about nothing, all of this information is fairly basic and can be found around the org VERY easy.
Tuesday, November 14, 2006 12:04 AM
you guys think single 2.25" mandrel bent catback, gutted cat (have on now) with 18" overall length dynomax muffler would gain me some since its not crushed like my current? im leaning more towards this setup after reading posts.
Tuesday, November 14, 2006 6:11 AM
I'd go 2.5" with a header. But that's just what me and my shop would recommend for a supercharger. And even tho it's illegal to even have it hollowed out, I would highly recommend getting your hollowed out cat and having a shop weld a pipe in it. That cat just hollowed out will be the end of your high EGV...it ruins the scaveging effect.
A resonator will not make backpressure but will take out thise ugly high pitched engine sounds. For the most part even a turbo muffler at the end of the pipe make a negligable difference in performance.
A couple of questions you should consider tho. When does the charger begin to make boost? Do you have a performance cam with an intake/exhaust overlap? And finally do you have a header?
The reason I ask is because if you make boost down low(1800rpm or so) then that's your torque the scavenging effect would make a disgustingly low increase. If you have a performance cam with an overlap the supercharger will force some exhaust out when the intake opens so again your scavaging effect is useless. If you have a stock manifold it doesn't really have the best properties for scavenging. That's why headers always yeild an increase.
'96 Cavalier Good ol' Pushrod 2.2
-24X,000 miles on factory build
-Some oil loss between changes, me thinks it be rings.
Tuesday, November 14, 2006 9:41 AM
i had a custom 2.5" on my N/A engine with headers, stock cat, no resonator, and fartcan. i didnt felt lost of pressure more like backfire i had and ricey sound .
But all that change pacesetter w/ 2.25" magnaflow all the way to the back + resonator
Tuesday, November 14, 2006 10:17 AM
do you guys ever find that your tire hits the muffler?
