upper and lower engine mounts? - Performance Forum
Sunday, November 05, 2006 10:16 AM
Ok i have look at the DIY . And nothin says about jacking up your engine for both mounts . So i take it as i dont need to then? I heard before you had too.
dark blue cavy
pdeez
Re: upper and lower engine mounts?
Sunday, November 05, 2006 10:27 AM
for the lower mount, you should place a jack under the engine to keep it from sagging as you remove the mount...
Sunday, November 05, 2006 10:34 AM
some people do, some dont. i never did the jack under the engine thing and did the mounts easy
Sunday, November 05, 2006 10:25 PM
The bottom mount you could do w/o a jack. It doesn't hold the engine up. The top one you should use
a jack.
Sunday, November 05, 2006 10:42 PM
^^ More of a safety thing as well using a jack.
Monday, November 06, 2006 3:02 PM
I just placed a floor jack under mine, just incase it moved. (It didn't move much, maybe 1/4" of movement)
It did make installing the lower mount alittle easier, because I could rock the motor (up and down) with the jack.
You can install it without any jacks though.
Tuesday, November 07, 2006 6:26 AM
Thanx for the info guys. I still hav not done it yet .
pdeez
