ok heres the scope i ran my car this spring and my best time was a 15.4. car is an 03 cavalier ecotec as you all know. mods were cone filter on stock tube, and fart can with other wise stock exhuast. i didnt have any rear seats, spare, jack, or rear deck, and the hood was off.
this winter i plan on doing some more modding. ive added rk 4-2-1 header, 2.25 inch piping, magnaflow cat, and magnaflow cat back.
i know i need a real intake, better mounts and pulleys...
i want to go na for now
what else do you guys think i need any words of advice. and my car in an atx
h&rs-rksport-magnaflow-ebc-stoptech-vss-jlaudio-jvc
You need HP tuners to remove torque management, Im not sure if there are any 14sec NA ecos though. You would need some serious weight reduction, I dont think its worth it, just get a bottle and your easily there.
A) 2.2L Ecotec N/A
1. Owen Stampflee, 14.446 @ 93.74
2. Ben Wenzel Jr., 14.551 @ 91.59
3. Jonathan Wehr, 14.826 @ 91.03
4. Mandy Mosley, 14.837 @ 90.74
5. ECOTEC, 14.873 @ 89.20
6. Jackalope, 14.896 @ 91.86
7. Paul Lombard Jr., 14.916 @ 90.60
8. nwcavi nick, 14.983 @ 94.23
9. bleco04, 14.999 @ 94.388
check out what they have done
Edited 1 time(s). Last edited Wednesday, October 18, 2006 10:20 PM
id be happy with 14.999 lol what are their mods any help is appreciated thatnks guys
All you really need is a full 2.25" exhaust with headers, cai to get into the 14s.
^not quite
Was_An_03_Cav wrote:id be happy with 14.999 lol what are their mods any help is appreciated thatnks guys
run a search on them...then you will see. good luck getting into 14's N/A, it would be pretty sweet.
FOR SALE: (5) '95-'99 Z24 Rims
14's in an automatic arent very easy at all N/A my best run to date is a 15.8 with all the mods in my registry and then i stripped the interior and deleted the balance shafts. i removed 300 lbs of interior (basically nothing left inside the car but the headliner, dash and 2 front seats) i pulled only a 2.3 60' on any of my runs and id guess if i got drag radials and decent struts and hit a 2.1 60' id be at a low 15 maybe without HPT.
now not saying my car is the best example and noone will be better then me with the same mods, just putting mine up as an example.
and im at about $1800 in mods ust in parts cause i was able to install everything myself.
definitely good luck it would be nice to see a 14 sec auto ecotec im hoping ill get there myself before i go boosted
The one, the only, ME.
also forgot to add i remove the serpentine belt for my few runs at the track, it eliminates driving the a/c and the alternater. this gets me .3 in the 1/4 pretty consistantly. id say make sure you can get it back on before you leave the track though just in case.
basically this eliminates use the use of getting pullies cause you pretty much cant let the engine rev any free er then just spinning the crank pully alone
personal proof they are very nice mods
i was thinking about the belt last night lol... it shaved .3 off your time is yours as stick my best time was a 15.4
mines an auto also
a mid 15 with basically no mods in an auto is damn good
take the damn body kit off.
'02 Z-24 Supercharged
the body kit wasnt on when i ran it smart ass
a nice bolt on hp, its a product from dei i believe it is. Its called cry02. The a co2 system. When co2 decompresses it gets very very cold. With this kit, theres a small bulb that sits inside your intake hose, and at the touch of a button, co2 decompresses and the bulb get really cold. Lowers your intake temps up to like 40 percent i believe. easy 20 or so hp without blowin yer engine with nos. just my $0.02
Son please, are you high on marijuana? You better shut your mouth, because you
probably drive a HONDA !
I have 14"s, and they suck.
Ugly hubcaps, can't wait untill I get a nice set of 17"s.
lol
I know we are not talking about rims, but when I read the thread title, all I could think about was the stock 14"s with hubcaps.
lol more about this co2 system how much...
so take the body kit off and run it withough the belt on, should get you there
but the problem is when you get 14s you wont be happy, then youll go for 13s, then 12s...
co2 system ... i wonder if anyone on jbody has actully used that thing and had it produce 20 HP
My bet would say no. And when the guy informing people about it talks about blowing motors with nos, I would also bet hes not that knowledgable on the subject.
I sure wish someone with a J would try that CRY02 system so we knew if it does anything.
It sounds like you really want to hit that 14 mark! Maybe you'll be the first to do it!
Good luck!
Here's some stuff to think about getting:
Lightweight Rims (I want a set of Motegi Traklites) 15in
Sticky tires...possibly Drag Radials...I don't know how an auto would handle them tho.
CF trunk (expensive)
Odyssey Battery
Maybe a lightweight flywheel
2004 Cavalier
13.2@105........
Mods...
BFG Drag Radials
Saab Turbo kit
2.5 exhaust, w/cutout
Spec Stage 2+ Clutch
Dean Wilson wrote:a nice bolt on hp, its a product from dei i believe it is. Its called cry02. The a co2 system. When co2 decompresses it gets very very cold. With this kit, theres a small bulb that sits inside your intake hose, and at the touch of a button, co2 decompresses and the bulb get really cold. Lowers your intake temps up to like 40 percent i believe. easy 20 or so hp without blowin yer engine with nos. just my $0.02
don't go getting this guys hopes up. There is no way the cry02 system is going to net you 20HP, let alone on an NA engine. I'd ask for your $0.02 back...
co2? removing serpentine belts?
give me a break...
do something more than exhaust and a half assed intake
intake (kinda done)
exhaust (done)
now move onto good stuff
real intake
throttle body
HPtuners EI/O+ wideband O2 for tuning and transmission control
cams
ported head
higher stall converter
reduce any large additions to weight such as systems, spare tire, jack, etc
interior peices are negligable at best its best to leave those alone
thats why I was never really into stripping my car...
nothing gayer than seeing a stripped out 14 second <sarcasm>beast </sarcasm>
worse comes to worse just swap in a 5 speed
id still like to know how hes running his times. im not at all doubting them im just jealous cause ive put aout 1800 into my car in parts alone just to hit mid 15's with my auto and i only weigh 2580 with an 1/8th tank of gas and without me in it
You can run mid to low 14's non aspirated you just need the cash for the merchandise. I am in montana at an altitude of 2300 above sea level and i run 14.8 to 14.4 without a bottle or turbo or supercharger. If i were back on the eastcoast i would be in the high 13's. Yopou just have to build it right. And i am still running stock cams. I have had some serious head work done and switched to a solid lifter and alot of bolt on's. The one thing that helped the most was the ecu tunning.
