will turbo eclispe injectors fit
DSM blue tops will fit, but they are low impedance so you'll either need something else controlling them or a resistor box. Also you will likley need to use the Ecotec orings instead of the dsm ones.
Would the hpt control them.?
No. As far as I know there is no way to change the PW time threshold or the PW current limit. You should be able to get a resistor box or rig somethign up to make them work. Check out what the honda guys are doing to get around this.
