WHO CARRIES GASKET SET,ROD , MAIN BEARINGS FOR ECO - Performance Forum
Tuesday, September 12, 2006 8:23 PM
I am swapping a 2.2L ecotec motor into my 98 z24 have run into a problem. I am boosting the ecotec motor so i have bought wiesco pistons and eagle rods to put in the bottom end. I cant seem to find a ecotec gasket set, rod bearings and crank/main bearings. Where do i buy these from becuase I cant find them anywhere? Also I am not sure if i need to do anything ot the timing of the car or if i need to do anything to the cams at all? Let me know thanks
Re: WHO CARRIES GASKET SET,ROD , MAIN BEARINGS FOR
Tuesday, September 12, 2006 8:36 PM
You can only get them from the dealership. The stock rod bearings are amazingly strong. The ones we took out of my motor had almost no wear signs on them. Same with the main bearings.
5K PB: 24:50
10K PB: 54:26
Tuesday, September 12, 2006 8:38 PM
U SHOULD GO ON MSN SO I CAN TALK TO U ABOUT IT RIGHT NOW MAN
Wednesday, September 13, 2006 9:25 AM
not trying to jeak but its related..im in the same boat..is it worth while to upgrade to clevitte bearings then?? phil
Wednesday, September 13, 2006 11:37 AM
word. u get yours runnign yet rhyne?
clevitte doesnt make any for the eco
hahn made 400whp on oem gm ones. and hell i dont even know when gm changed theirs. im sure it was around 500-600.
just go to your local dealership. tell them u want new rod and main bearings.
as far as gaskets go. its up to you. every gasket i took off the engine, i ordered a new one to replace it. may not HAVE to... but with all the money involved... since its already appart.. why not just do it and never worry about it again?
http://www.myspace.com/15102113
Wednesday, September 13, 2006 12:24 PM
GMs replaced their crankshaft main bearings and connecting rod bearing in the 600-1000hp section. I'n not sure which bearings you are talking about but for the connecting rod bearings they replace them with CLEVITE part number #1663H or HX, on page 77 of the ecotec build book. The main bearing set that is recomended in the book is from GMPP #21018819. The stock head gasket is 24444091. I haven't read through the book in awhile, but I didn't see how much horse power it can take, but in the back of the book they list suppliers and for head gaskets they have SCE Gaskets . Hope this helps you a little.
Wednesday, September 13, 2006 2:45 PM
Headgasket: Cometic
Rod Bearings: GM Dealership
Main Bearings: GM Dealership
Timing Cover Gasket: GM
Anything else I forgot: GM
I can get you the HG from Cometic though. Shoot me an IM or email.
5K PB: 24:50
10K PB: 54:26
Wednesday, September 13, 2006 5:00 PM
GM Race engines use STOCK OEM GM Main Bearings and HONDA Rod Bearings. They have the crank / rods made so they use Honda Rod Bearings.
Wednesday, September 13, 2006 10:00 PM
you can use a stock headgasket, ive never heard of anyone blowing one
