quick question.. 4 wires on it.
black=ground
gray=tach
red= pink wire off coil pack
red w/green= pink wire off coil pack
so my question is. which wire comes DIRECTLY off the coil pack. the red or red w/green. im just confirming i have it wired right. would the car even run right or at all if i had them backwards?
i have the red w/green wire coming directly off the coil pack. so the signal goes through the tach adapter directly off the engine, then travels through the tach adapter coming out the red wire, then connected back into the pink wire.
is this correct or is it backwards?
http://www.myspace.com/15102113
@!#$. lemme try this again... sorry im kinda pissed.
i have the red w/green wire coming directly off the coil pack. so the signal goes through the red/green wire to the tach adapter. then travels from the tach adapter through the solid red wire, then connected back into the pink wire.
correct or backwards? and would it run if i had them wrong?
