I've got a DCSport Header for the 2.4, and was wondering if a the end of the header where it become the two hole flange if this
gasket would work. I guy from work recommended these, as he said they seal better, and i felt that if i ever decided to use the straight pipe, i wouldnt have a gasket other than the one that came with it. I would assume the other end (the 3 hole side for the cat eliminator pipe), is a standard 3 hole, but was unsure about the 2 hole flange. I guess the pipe from the header is 2.25, while the eliminator pipe is 2. I've got a cat mated the flange now, with a mix of 2.25 and 2 in piping (might be 2.25", cant remember how the shop did it).
Question is, will that gasket fit at the end of the collector for the Header? (where the 2 bolt flange is)
It should.
They're usually standard sizes.
As long as the inner diameters match up on the pipe and gasket.
Good find.
How are you liking the header so far?
I'll be using that one or Pace one day in the future.
-M
most oval gaskets are all the same size , mainly youd be worried about the main hole size
bolt spacing is usually enlongated to fit with different width bolt patterns
Mastin wrote:It should.
Good find.
-M
Thanks guys, as far im aware, its 2.25", i like the header, it looks good, added a lot of noise to the motor (plus a Magnaflow Hiflow cat), but was worth it. I got it to keep some low end, as most mods are for top end, but didnt want to lose any, and i didnt.
