2.3 ho manafold need help?? - Performance Forum
Monday, July 31, 2006 7:59 PM
I got a 2.3 manafold and was wondering can you still use the 2.4 t/b or do i have to use the 2.3 and how do i mod the 2.4 if i can use it. Also what length bolts do i need when i get the adapter flang?
Re: 2.3 ho manafold need help??
Monday, July 31, 2006 8:04 PM
You can use the 2.4, you just tap out the holes in the throttle body to fit the bolts.
Monday, July 31, 2006 8:10 PM
and mod your cable bracket to fit (redrill one hole) as well as tap another hole on your TB.
Sask GM Performance (formerly SaskJbody) president
Monday, July 31, 2006 8:14 PM
mattf wrote:and mod your cable bracket to fit (redrill one hole) as well as tap another hole on your TB.
Huh?
I didn't have to do any of that... The cable bracket I had to notch out , but only because of the auto tranny. I didn't have to tap any other holes or redrill a hole in the cable bracket.
Monday, July 31, 2006 8:15 PM
if you can find a 2.3L TB i would use it. Its 56mm over the 54mm of the 2.4L TB.
Click the banner to enter the best Quad4 & Twin Cam site on the internet.
Monday, July 31, 2006 8:16 PM
May i make a suggestion? even though you can use the 2.4tb, a better choice would be the 2.3tb because its larger. 56mm as opposed to 52mm.
Tuesday, August 01, 2006 12:50 PM
cool thanks guys that helps
Wednesday, August 02, 2006 4:59 PM
And i think if your gonna go with 2.3 tb, u need a 2.3 tp sensor, map, and i think IAC.
Friday, August 04, 2006 2:31 PM
Huh?
I tapped the other hole so I could put a bolt into the TB to hold the braket on. This seemed better than using a nut/bolt for that hole. I tapped the other hole so the bolt that bolts the tb to the mani could fit in, iirc.
