Tapping fuel rail? - Performance Forum
Tapping fuel rail?
Monday, July 17, 2006 10:18 AM
I need to add a fule pressure gauge onto my 03 ecotec fuel rail. The gauge says it has a 1/8 npt connection on the back. What is the exact size of the tap im going to need?!
thank you in advance.
Re: Tapping fuel rail?
Monday, July 17, 2006 10:24 AM
1/8th NPT tap
Its a pipe tap if that helps, available at most hardware stores.
Monday, July 17, 2006 10:27 AM
it does thank you
Monday, July 17, 2006 10:32 AM
If you use a 1/8" NPT to 1/8" NPT nipple, you'll need a 1/8" tap
EDIT: Bah, trust me to take too long to respond...
Edited 1 time(s). Last edited Monday, July 17, 2006 10:32 AM
Monday, July 17, 2006 10:41 AM
wow , john knows how to give US measurements , LOL j/k
but yeah what shifted said , home depot , lowes , ace hardware , sears
will all have that tap size , and look at the tap it will tell you the drill size you need also
make sure you flush and blow all the shavings out of the rail , and make sure you dont have any leaks
Monday, July 17, 2006 12:15 PM
I don't know why GM even bothers using metric... no stores (even in Canada!) carry a large selection of metric hardware... so it's damn near impossible to find the right replacement hardware when you break hardware (heh heh.. bust a nut...)
Only thing we've got that's good.... the Robertson head screw.... way better than that Torx garbage
Monday, July 17, 2006 12:54 PM
if you dont want to tap the fuel rail then you can use the -4 fitting on the fuel feed line.... you would need to convert the -4 to 1/8npt ....
the braided line on the fuel rail runs to a mechanical fuel pressure gauge.... just a thought... good luck.
Monday, July 17, 2006 1:15 PM
John Lenko wrote:I don't know why GM even bothers using metric... no stores (even in Canada!) carry a large selection of metric hardware... so it's damn near impossible to find the right replacement hardware when you break hardware (heh heh.. bust a nut...)
yeah i agree the torx suck , but atleast they do share some size with alen's , so if you strip the torx part you still got a chance to get it off
Tuesday, July 18, 2006 9:56 AM
Another pic from the N20 FAQ section
Tuesday, July 18, 2006 10:02 AM
Tuesday, July 18, 2006 11:17 AM
he knows that pressure tap is there
Tuesday, July 18, 2006 1:25 PM
Yea, I figured as much, but if someone else may stop by and read this and not really sure with the first pic is, the second link will help them.
If that is the wrong way to do busniess here. Well then.....
Tuesday, July 18, 2006 2:23 PM
yeah true
us 2.4 people have to do the drill and tap , GM didnt give us a test port
Tuesday, July 18, 2006 2:32 PM
so i just go out and buy a 4an stainless hose, how do i hook that onto the 1/8 NPT sender i have for my electronic fuel pressure guage
Tuesday, July 18, 2006 3:38 PM
if you can get that adaptor piece , id set it up similar to this
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=160006795215&ih=006&sspagename=STRK%3AMEWA%3AIT
not really any need for the hose
or just drill and tap and put the sender in the fuel rail , which is how my 2.4 is done
Tuesday, July 18, 2006 4:32 PM
^^^ Yea just an adapter is needed.
Yea GM did screw you guys out of that test port.
