Wiring Issue, please help. - Performance Forum
Sunday, June 25, 2006 12:54 PM
So my car has had this stupid issue for the last 3 months or so and I can't seem to find the problem.
I will be driving along with lights on or off, and all of a sudden all my gauges turn off, my radio turns off (usually resets my clock) my dome light won't work, my brake lights don't work, and my driver side power door lock wont work.
Usually to get it working again, I pull the high beam switch back a little or turn my lights off then on, and everything comes back on. If that doesn't work to get everything to turn back on usually I can go under the hood to the huge wiring clip and play with that and everything turns back on.
Sometimes, it happens every 5 minutes or more, and sometimes won't happen for a day or two.
Re: Wiring Issue, please help.
Sunday, June 25, 2006 12:55 PM
oh yah, the blower fan stays on, but if I have the A/C on, the pump stops running, but blower keeps going, WTF?
Sunday, June 25, 2006 2:59 PM
better had you asked here
http://www.j-body.org/forums/list.php?f=11
Sunday, June 25, 2006 3:18 PM
my bad, I reposted there, I was looking for that forum, but couldn't find it, thanx
