rpm signal wire - Performance Forum
rpm signal wire
Sunday, May 28, 2006 3:08 PM
where on the pcm of my 97 sunfire gt 2.4 ld9 is the rpm signal wire?
Re: rpm signal wire
Sunday, May 28, 2006 8:38 PM
off the ignition module?
Re: rpm signal wire
Sunday, May 28, 2006 9:00 PM
TPS fuse in the fuse box located in the engine bay.
Blew it up, build numbers coming soon
Re: rpm signal wire
Sunday, May 28, 2006 9:59 PM
do i need a tach adapter then or what wire is it
Re: rpm signal wire
Monday, May 29, 2006 6:25 AM
Pink wire coming off the IDI cover. No tach adapter needed.
Re: rpm signal wire
Monday, May 29, 2006 10:31 AM
You might have a tach slot in your fuse block under your hood, my 96Z did. It's a white wire.
