adj fuel pressure reg. for 2200>? - Performance Forum
Wednesday, May 17, 2006 6:12 PM
does anyone have a adj. fuel pressure regulator on their 2200? if so where did you get it from and how did you install it?
Re: adj fuel pressure reg. for 2200>?
Thursday, May 18, 2006 9:23 PM
I do not have one but from what i can remember the ohv requires the camaro version from the lt1 equiped maro. the 2.4 uses the Corrvette version, and the only differance is that the tab is mounted on the oposite side of the reg to mount it to the rail.
There is the link to the one I plan on getting eventually.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=AEI%2D13107&N=400300+4294880914+4294902722+4294908216+115&autoview=sku
I'll see if I can find the old post with the info in it and i will post.
Thursday, May 18, 2006 9:44 PM
here is what i found in a quick search.
http://www.j-body.org/forums/read.php?f=2&i=309777&t=309580#309777
I also found some conflicting info.....so I guess I will have to look into this again just to make sure I got the right part #. Also from posts i went through agent omega is a member who used a b&m honda reg on his 2200 rail but it required some modification as well. Well im off to bed i got work in 7 hrs.
later
Thursday, May 18, 2006 11:36 PM
Pfftt I just use my FMU. lol
