Gas tank weights. - Performance Forum
Gas tank weights.
Tuesday, March 21, 2006 7:49 PM
I guess some J's came with a plastic gas tank versus a metal one (at least, I'm showing plastic gas tanks available in the Mitchell book). Anyone know the weight differences between the two?
Re: Gas tank weights.
Tuesday, March 21, 2006 7:53 PM
Need edit
Anyways. Plastic gas tanks: #22709902 in 2000-05 (as far as my book goes)
Steel tanks: #22592046 (95-98) 22617055 (99-00) 22704610 (01-05)
Wednesday, March 22, 2006 7:40 AM
Don't know the weight difference, but the fuel line hook ups are different I believe, not a direct swap, but doable.
Wednesday, March 22, 2006 8:51 AM
I KNOW the metal one is about 1.5 times as heavy, but the fuel lines do not run the same.
I was going to swap a plastic one in till I saw where the fuel lines were, and became to lazy.
Wednesday, March 22, 2006 10:39 AM
What about the fuel pump mounting ring and mounting depth? Would it be pssible to mount the older pump assembly in the newer tank without alot of additional work?
Wednesday, March 22, 2006 10:50 AM
BTW, I changed my fuel pump a couple weeks ago, and the steel tank wasn't all that heavy, so I don't think that changing to a plasic tank alone would make a big difference, not worth the price of a new tank, if you could find one. Now, if you can get one from a salvage yard and do some other low buck weight savings, it might help.
Wednesday, March 22, 2006 11:15 AM
If your that worried about weight just take the gas tank out and put a small fuel cell inside the car.
15.149 @ 91.26mph 3-18-2006
Wednesday, March 22, 2006 12:03 PM
MadJack wrote:... I don't think that changing to a plasic tank alone would make a big difference, not worth the price of a new tank...... if you can get one from a salvage yard and do some other low buck weight savings, it might help.
steel tank is a 16 gallon , 95-99
plastic is a 14 gallon , 00-05
filler neck , evap , and fuel pump modules are all different
