Installing cat-back, where to cut? tips? - Performance Forum
Friday, March 03, 2006 3:25 PM
I am installing my catback exhaust tommorow morning. Do i have to cut the factory exhaust to remove it? Any tips? I heard you need to cut somewhere near the axle back section to be able to remove the stock setup? Is this true? If so where should i cut?
Re: Installing cat-back, where to cut? tips?
Friday, March 03, 2006 3:35 PM
Its either cut it or remove the whole rear axle. Cut it in the straight section before it bends up to go over the axle, This way its easier to reinstall it if you ever need/want to. Have fun.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Friday, March 03, 2006 3:36 PM
you shouldn't have to, three bolts, undo the hanger for the muffler and wiggle it out.
Friday, March 03, 2006 4:01 PM
ooh, the axle back is a bolted on piece? If I dont have to cut it, That would be much better, but I got a saws all just in case. Its an RkSport Cat-Back. Hope all goes well. Thanks.
Friday, March 03, 2006 4:55 PM
^^^No. You will have to make one cut before it bends up to go over the rear axle beam. That is it, just one cut.
Friday, March 03, 2006 5:27 PM
^^ exactly... the factory catback it's a whole one piece....if you want to you can cut directly after the cat or like state above before it bents up
CaviFL45
Friday, March 03, 2006 5:51 PM
before it bends up on the muffler side of the axle? or before it bends up on the cat side of the axle?
Friday, March 03, 2006 5:56 PM
just go nuts with the sawzall
Friday, March 03, 2006 6:03 PM
To get mine off today I had to cut the exhaust as close to the axle beam as I could. Too far away and you can't get it out. Learned that one.
Friday, March 03, 2006 6:23 PM
just hand tools and like a ratchet set to remove the old one from the cat? little WD-40 maybe?
Friday, March 03, 2006 6:50 PM
^^^Yup. I used a little WD-40 and the bolts came out pretty easy when I did my exhaust.
Friday, March 03, 2006 11:21 PM
With mine, i had to cut right in front of the axle, wiggle everything out. Then I had to drop the axle, to put the bend over it. Another 45 minute job turned into 2 1/2 hours....
http://www.cardomain.com/ride/2265283
Saturday, March 04, 2006 9:18 AM
Cinny wrote:you shouldn't have to, three bolts, undo the hanger for the muffler and wiggle it out.
Wrong, You can not get it out with out cutting it. It's one piece, No way to wiggle it out.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Saturday, March 04, 2006 4:37 PM
Ok, the kit is installed. It was easy to put on but i had some trouble taking the old one off. Mainly because of the bolts at the cat. Plus, when i went to put on the rksport kit, they didnt give me bolts and nuts for the end that bolts to the cat!! luckily, Home Depot had exactly what i needed but i was very pissed. After the install all fits well. The kit hangs a bit lower then the stock one, but nothing to serious.
Thanks for all the tips on the install.
I love the kit, it looks and sounds good, but i would never reccommend it to anyone because of the missing pieces, that were missing from a sealed bag. (plus once i ordered mounts from rksport for my motor and then they "never heard of the order" two weeks later. I dont like RKsport. I do like there exhaust though, its pretty much a way less expensive Magnaflow.
