Tac wire for 2.4L - Performance Forum
Tac wire for 2.4L
Saturday, February 18, 2006 7:47 AM
I still haven't gotten the remote start feature of my autopage alarm working because i can't get a real answer from anyone.People say violet,white are white are pink.
I thought i would post this here because you guys have probly put in Tachs on 2.4's etc
If you could please tell me what colour wire and where it is that would be great
Re: Tac wire for 2.4L
Saturday, February 18, 2006 9:12 AM
It's def the pink wire in the IDI harness. You may need to use a tach adapter to make it work with your remote start though. MSD sells what's called the "tach driver" and it's about $50 give or take a few bucks depending on where you get it.
Saturday, February 18, 2006 10:16 AM
Do you mean this plug?????
Because i already tested the wires and found that the violet/white and the yellow to get the same reading.
But i haven't tested it yet
Saturday, February 18, 2006 4:24 PM
Yes, that plug. You need the pink wire though. That's what I have my tach driver hooked to that runs my RPM window switch on my nitrous kit.
Saturday, February 18, 2006 4:32 PM
Depends on what year car you have. The 96's to 99's have a Tach fuse in the fuse box under the hood where you can get a Tach signal. The 00's don't have that fuse, but you can connect directly to the C2 Pin 10 connector on the ECU for a full tach signal.
Sunday, February 19, 2006 12:21 AM
its not a fuse... just a open pin... its also pin10 on the black conector @ the ECM. No need to spend $50
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Thursday, February 23, 2006 8:12 AM
So is that in that harness that i posted a pic of and is that by the air box
Monday, February 27, 2006 6:07 AM
TTT
Monday, March 06, 2006 2:17 PM
Okay,so is this pin 10 im looking for in the pic i should before are is it in the budle of wires by the airbox.
Monday, March 06, 2006 2:18 PM
Pin 10, connector 2 on the PCM, not in the fuse box, thats only for the pre-99's.
Monday, March 06, 2006 2:51 PM
MSD #8913.
Im not sure on the 2.4 but i know exactly what wire to wire the MSD box to on the Ecotec.
I paid 70 buks at summitracing for my box.
