same old @!#$ - Performance Forum
same old @!#$
Friday, February 10, 2006 4:48 PM
I'm planning on buying an o2 sensor simulator. I've seen them for $20.00 bucks and up. I don't want to spend money on junk, anyone know of one that actually works to replace sensor 1 bank 1.
Re: same old @!#$
Friday, February 10, 2006 4:53 PM
You can't replace bank 1 sensor 1, you MUST have a real sensor there.
Re: same old @!#$
Friday, February 10, 2006 4:58 PM
I'm getting the slow reading code. how do you fix that.
Re: same old @!#$
Friday, February 10, 2006 5:02 PM
Replace the sensor
Re: same old @!#$
Friday, February 10, 2006 5:12 PM
i have and it just keeps throwing the same code. After about a week or less.
Re: same old @!#$
Friday, February 10, 2006 5:14 PM
Do you have the wires modified at all? Have you checked for frays or damage from the sensor to the ECU?
Re: same old @!#$
Friday, February 10, 2006 5:19 PM
I soldered the wires used shrink wrap and all the good stuff. Everything looks good.
Re: same old @!#$
Friday, February 10, 2006 5:20 PM
Are they modified though? Lengthened? Different gauge wire?
Re: same old @!#$
Friday, February 10, 2006 5:22 PM
it's lenghtened using the wires that came with the pacesetter kit.
Re: same old @!#$
Friday, February 10, 2006 5:25 PM
Thats why, everybody who lengthens the wires ends up getting slow response codes.
I don't know the fix. Eric may be able to give some more insight.
Re: same old @!#$
Friday, February 10, 2006 5:29 PM
Thanks I really appreciate the input. Maybe he'll check the forum and let me know somthing.
Re: same old @!#$
Friday, February 10, 2006 5:31 PM
Eric who? I searched the name and came up with like 20 Erics.
Re: same old @!#$
Friday, February 10, 2006 5:32 PM
Rembolt
Re: same old @!#$
Friday, February 10, 2006 6:01 PM
make sure you DONT modify the sensor wires....... they have a specific resistance value. When lengthening the wires ONLY lengthen the harness wires (car side of the plug) not the sensor side.
ALSO..... adding a A/F Gauge will also cause problems, and possible slow responce codes......
and SHIFTEDs being a post whore tonight
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Re: same old @!#$
Friday, February 10, 2006 6:04 PM
oh..... and fill out your registry...... cant tell what engine/trans....... or anything from your registry..... so its really hard to help you...... I assume you have a '02 Cavalier..... from your user name....
pimpinthecavy02
Re: same old @!#$
Friday, February 10, 2006 6:08 PM
Brian, I'm only a post whore tonight because I don't have you around to keep me busy
Plus the car isn't in a drivable order, so I have nothing else to do, lol
Re: same old @!#$
Friday, February 10, 2006 6:33 PM
They make an extension for the 02 sensor.
Re: same old @!#$
Friday, February 10, 2006 7:39 PM
Thanks guys thats a real help I'm buying a new sensor tomorrow will take it from there. Anymore info that you got will help. Thanks again.
