So what all did you have to grind/cut to fit it...the bracket for the throttle cables?
elkahosso wrote:So what all did you have to grind/cut to fit it...the bracket for the throttle cables?
I had to grind it down some of the throttle bracket so the 90• elbow would fit better. You don't have to, but I think it fits better this way (less of an angle). I also had to drill a small hole in the intake, and add a rubber grommet for one of the lines that ran to the stock intake and remove the bracket that was on the new intake.
The silicone hose they supplied is about 3 inches short, so I just adapted another hose I had laying around until I have time to run to the parts store and pick up the proper size.
so whats the tubing made out of plastic or aluminum,and by the way good find.
Todd Eisenhard wrote:so whats the tubing made out of plastic or aluminum,and by the way good find.
Its aluminum. Weighs 4 pounds with the filter, silicone lines, and clamps.
good find, thanks i ordered one i have a 2.4 post pics when i get it
very nice work.
The blood means you did it right.
you said you had to remove the bracket on the intake,so what did you do to bolt in place so it wouldn't bounce around in the engine compartment.
Todd Eisenhard wrote:you said you had to remove the bracket on the intake,so what did you do to bolt in place so it wouldn't bounce around in the engine compartment.
Right now its help up with a custom bracket (metal brace, and a hose clap). Once I have time I will weld on a proper one.
be weary of that bracket on the bend in the elbow. i had a cheap intake and the bracket actually broke off poor weld + aluminum is not forgiving. may not be an issue if you have motor mounts
14.82 @ 97 mph
did that bomz intake come with everything proper to the ld9? like, hole and grommet for iat, and the pcv(damn is that right? head hurts after i get outta college and i can't remember sometimes)
im not really thinkin about buying it, i'm going to make my own soon /dont like how it's 3' in diameter, i'd rather try a 2.5 first/plus have a k$n
well if it's all on then how do you like it? not really askin for performance gains cause you prob wouldn't be feeling much, but how did the sound change? in other words are you happy?
You will feel any intake that is better then sound, you will hear it too.
Save our Environment, Plant a bush back in texas.
nice. I also love the rainbow vacuum line. nice touch. (jk get an all black 1!)
looking good, looks just as good as my typhoon and thats MADE FOR the ecotec lol.
LOOKS nice but semi-Ebayish does it work well?
Now that I have it mounted right, and all the proper hoses it works really good. There is a very noticable power gain in take off and in the high RPMs. The exhaust is louder, and there is a pretty deep sound coming from under the hood when you floor it. I'm sure it will be better when I add the K&N filter too.
I'm very happy with this intake. Not only do I get better performance/power I have noticed better gas millage aswell.
