What's the best way to have a header, high flow cat, and a glasspack installed? I want to do the header myself, but I can't weld. Would the best thing to do be to drive the car to the exhaust shop with just the header and have them finish it?
I can buy clamps at Autozone right? Will the header reach the rest of the exhaust without the converter? I assume it would be okay to let the o2 sensor dangle for the trip and the CEL would turn off after I go it in the converter right?
Almost forgot, how what do the header bolts need to be torqued to?
The exhaust manifold gasket: would that be at Autozone or some other store, or is that an online thing?
I'll let you know how it goes this weekend. Thanks for all your help and advice!
I went to O'Reillys Auto Parts, and they said they'd have to see the header to sell me the right gasket, it's just the stock exhaust manifold gasket I need right?
I went to Autozone tonight and asked for a gasket. They didn't have one, so I asked if they had one for a Sunfire, no go. The guy said it was just machined together. I told him that wasn't the case. He said I should use the one that came with the header. Would I be okay using the stock one with some gasket sealer? I hope so.
Okay, ideal install is 7.5 hours from now. Here's what I do (someone please correct me if I'm wrong):
1. Put car on ramps and cut downpipe right in front of the converter.
2. Unbolt exhaust manifold and remove from the top.
3. Bolt in the header.
4. Get under car and olt downpipe to header.
5. Fasten downpipe to the stock converter.
6. Drive to exhaust stop to have everything welded.
Is there anything I missed? I'm a little apprehensive about doing this mostly by myself.
Oh, before this I want to do the lower engine mount.
1. Jack up car.
2. Remove passenger tire.
3. Support the engine with another jack.
4. Remove stock mount.
5. Wiggle new mount into place. (How much do I tighten the new mount? (Tight, Stupidly Tight, As Tight as I can?))
6. Replace front tire.
7. Begin header install.
Again; anything I missed?
I've read both of these things are fairly easy to do, but I want the peace of mind before I start doing this.
