please help with ho mani - Performance Forum
Tuesday, February 07, 2006 7:58 PM
ok i put my ho manifold in. and ever thing is hooked up it runs and drives. but when iam idling and rev it to about 2500 it will drop down to 600 or 700 rpm and almost dies then revs it self up a lil then drops down agane and almost dies. i have no clue what it could be . please help thanks
Re: please help with ho mani
Tuesday, February 07, 2006 9:26 PM
what sensor and TB combo did you use.
Sounds to me like an IAC sensor issue. If you used the 2.3 TB use the 2.3 IAC valve or it will not ever be right, if you used the 2.3 valve get a new one.
Make 100% sure there isnt a vaccuum leak newhere as well.
Tuesday, February 07, 2006 10:45 PM
yes check to see what codes were thrown if any, when i swaped mine i threw a few codes, i had the same @!#$ty idle you are describing, i cleared my codes and the car ran great after the codes were cleared
Tuesday, February 07, 2006 11:54 PM
Reset your IAC. It's been a while since I've done it...
Turn to key to the on position but don't start the car. wait about 15 seconds. turn it off.. wait 15 seconds. repeat for 3 times I believe?
on the last time turn the car on.
Someone correct me I know my explanation is totally wrong.
Wednesday, February 08, 2006 5:54 AM
i have the ho manifold and i used the stock 2.4l t/b and am i spose to plug my egr with a 97 z24 with a man trans?????? cuz i did could that be a prob????
Wednesday, February 08, 2006 10:18 AM
if your EGR is unplugged there is probably a code stored and causing your car to go into "limp mode"
Wednesday, February 08, 2006 11:03 AM
how do i get it out of limp mode? or is it just the turn key on 15 sec then off 15sec 3 times????????
Wednesday, February 08, 2006 11:58 AM
the turn key off thing is to reset the iat sensor.
you need to hook it up to a code reader and clear te code to get it out of limp mode
Wednesday, February 08, 2006 7:29 PM
I never did get the 2.3L TB to work on mine. It did the EXACT same thing. I just stuck with the 2.4L TB. But my guess would be that my IAC was shot. It didn't look too hot. Get a new IAC for the 2.3L and try that.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Wednesday, February 08, 2006 9:11 PM
im in the process of doing mine as well...i also have a 97 z24 ...but i heard if you use the 2.3 TB then you should use the 2.4 IAC with the 2.3 IAC plunger...is this correct or you just use a 2.3 IAC with the stock wiring harness....
Thursday, February 09, 2006 3:19 AM
if you're using the 2.3 TB use the 2.3 sensors. They should plug in with the 2.4 harness
if you're using the 2.4's TB well.. that should be obvious then.
Thursday, February 09, 2006 7:31 PM
ok i ran the codes today i had a i got a iat code then i fixed by hooking the iat back up and i still have somthing going on no codes tho
it seems like when i put the defrost and the rear defrost on it like doesnt give enough gas i will kinda cut out and stuff as iam driving and i shut off the defrost then it better agane someone please help
