I've got the header already.... just wondering what the diameter of the exhaust ports on the flange are so I can port match my spare head.
Thanks,
Wesley
Do you have a ruler or caliper?
I think that was a little to obvious....
I needed someone to check... hopefully someone who has one off there car... mine is installed right now and I'm not able to remove it at the moment
tube diameter wont help any ways
you got to match port location
again.... I asked for it on the flange... not tube....
thanks
as i said , you need the actual port location on the flange to match it to
or pretty much the 97-older 2.2 exhaust gasket
[quote=97cavie24ls(JDM&00s/c sedans™)]as i said , you need the actual port location on the flange to match it to
Yup, But good luck porting your head to the obx, Its a rip off of the pacesetter and is universal between the 95-97 2.2and the 98+ 2200, Hard to explain but when you port match to the obx gasket you can run into the water ports in the head if your not careful
Now lets see how many toss up the ol
flag so I can prove it.
mmmm ok... thanks guys... guess I'll have to pull it off to see
