in need of some info and pics of the swap ...2.3l oil pump into a 2.4l engine thanks
littlejohn1
scudz24 wrote:http://www.ny-jbodies.org/
go to liabrary and then 2.3 swap
yup, he beat me to it.
it doesn't have pics does it?
littlejohn1
no it doesnt have pics, u'll have to search
Check my cardomain, page 3. Link in my sig.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
hey john check your email for the pics. also if you haven't already check out page two on the performance faq there is a write up on it.
View my MySpace
thanks for the pics. in the article it does not say you have to add onto the pan in depth you just have to grind off some flanges is the adding onto just to hold more oil in the pan??
littlejohn1
couldn't you just bend the pickup tube up just enough to clear the bottom of the pan??
littlejohn1
john miller wrote:thanks for the pics. in the article it does not say you have to add onto the pan in depth you just have to grind off some flanges is the adding onto just to hold more oil in the pan??
Oil pan depth
is a definate issue. Bending or smashing the oil pick up in not the right way to go, you'll need a modified oil pan like the one Miller Performance sells.
when you add depth to the pan how about the lower rad. pipe that runs from behind the pan to the lower rad. hose what do you have to do toit because it bolts to the pan also??
littlejohn1
john miller wrote:when you add depth to the pan how about the lower rad. pipe that runs from behind the pan to the lower rad. hose what do you have to do toit because it bolts to the pan also??
Good question, anyone have an answer?
nothing has to be done to the rad pipe.....
_______________________
** Flat Broke Racing Inc.**
Hey John Miller how much for one of your modified oilpans, as I will be embarking on an engine buildup very similar to Skilz except I'm also going to do a ported 086 head swap at the same time. Also do you make or have any windage trays for the 2.3 oil pump swap? I can be reached at dcyoung@co.pg.md.us thanks in advance for any help you can give.
2000 Z24 5spd header & catback for now.
No modifications are needed for the lower rad. pipe.
