gas tank 95 to 01 Same ? - Performance Forum
Saturday, January 14, 2006 10:20 AM
Hi i am looking at a fuel pump but i am not sure if the tank on my 01 sunfire is the same from a 95
thanks
mike
Re: gas tank 95 to 01 Same ?
Saturday, January 14, 2006 10:26 AM
There were two different tanks, but the pumps should be interchangable.
Saturday, January 14, 2006 12:34 PM
95-99 is a larger capacity metal fuel tank. 00-05 is a smaller capacity plastic (composite) tank. There is a slight difference between 00-02 and 03-05 tanks as well, there's a separate overfill pipe on the top side of the tank. But it doesn't affect how it works.
I don't honestly know if the older sender will work in the new tank.
I do know... I swapped the whole tank from an 03 into my 00, and it worked fine. I also know.. you can use a 99 tank on a 00 car, it will plug in and work just fine.
The sender units changed for the 00 model year, but it appears to be electronically-compatible with the older cars sender units anyway.
Saturday, January 14, 2006 2:35 PM
Lenko, John Lenko wrote:95-99 is a larger capacity metal fuel tank.
They're the same from 92+, which makes it nice for those of us 2nd genners who want to swap to the plastic tank in 00+.
