hey guys, is there any truth to this Hyper Ground System S-Type? Does it really give that much power and will it do it for a sunfire? thanx in advance.
http://www.cardomain.com/ride/2197727
the grounding kit will NOT give you any Hp gain NOTICIBLE. It MAY give you 1-2hp because of less resistance on the electrical system. The only thing it does is help the electrical system work correctly. It will help on the head light, the sound sytem, idle and start up from what I've heard. If you know electricity, you can build yourself a "kit" for less than 20$.
Gilles
2.3 Ho
Mfk-223 wrote:the grounding kit will NOT give you any Hp gain NOTICIBLE. It MAY give you 1-2hp because of less resistance on the electrical system. The only thing it does is help the electrical system work correctly. It will help on the head light, the sound sytem, idle and start up from what I've heard. If you know electricity, you can build yourself a "kit" for less than 20$.
More helpfull for electrical. ie: if you have HIDs or a system, or under drive pulley. Good idea to make your own, there have been posts on how to do it, just search up "ground kit" in "audio and electronics" section. Might give you alittle power, but I wouldn't expect much.
stupid question , why is your title misleading ???
the title should read about hyper grounding , not about a company
