new high flow cat sounds tinny/raspy? - Performance Forum
Monday, January 02, 2006 7:02 AM
alright, so i just got a whole new setup from the engine head all the way back, including a new magnaflow 94035. the car doesn't sound tinny/raspy (when listening from the muffler), but when i stick my head out the driver side door and listen underneath the car, i can hear the cat (and at least the area around it) sounding tinny/raspy when i give it some good throttle. i have a header, high flow cat, long resonator, super turbo muffler. i took it to the exhaust shop thinking i had a leak but they checked everything from the head gasket to the tailpipe and said i have no leak whatsoever. they're a good shop and even covered my tailpipe to force the exhaust out a leak (and make a whistle sound) but still, nothin.
i've only had the cat on for a week, could it be that its just new and needs to break in? or do i have another problem? or is this normal?
thanks your input.....
Re: new high flow cat sounds tinny/raspy?
Monday, January 02, 2006 7:41 AM
i have a magnaflow 94035 on mine. when i first installed it, it sounded tinny and made a slight ticking sound. that sound went away after about a month
Monday, January 02, 2006 9:59 AM
i've never put one one a 4cy before, only on v8 and the sound improvment was awsome so i was thinking that you might have a leak, but after all you said about checking for one........ just listen to alias. i was just bored and wanted to type something!
Monday, January 02, 2006 6:55 PM
yes alias, when i first start the car too, i can hear also a slight ticking, similar to the raspyness....
Monday, January 02, 2006 8:32 PM
Ticking huh? Did you guys with ticking sounds from aftermarket converters weld them in or clamp them in? Clamps are, of course, notorious for not having the best all-around seal in the world. With my last car, the previous owner decided to install a universal converter when the stock one crapped out with no prior experience and without taking the car to a shop for welding. He clamped it in, so it ticked, and I welded it in myself when I bought the car and it never made noise ever again.
Monday, January 02, 2006 10:46 PM
it's an exhaust leak.
Monday, January 02, 2006 11:48 PM
I have the same problem out of my new mangaflow cat...after it warms up it pretty much goes away....i'm pretty sure its not an exhaust leak because i took mine back to the exhaust shop the guy lifted the car up while running and if you listend you could hear the exhaust gases going through the cat, and when reved it was louder like a raspyness...he checked for leaks there was none to be found...the guy just suggested that it was were the cat was high flow, sounds reasonable to me...
Monday, January 02, 2006 11:52 PM
well... we always have to remember that cars sound raspier when they are cold. i have the magnaflow 53005 and for the first few minutes i drive it, it's raspy and nasty sounding in higher RPM's. but once it gets warmed up, not a single bee sound to it.
Monday, January 02, 2006 11:54 PM
ya mine sounds good once it warms up to running temp....still can hear the flow but it dosn't have bee sounding to it...
Tuesday, January 03, 2006 1:55 AM
I did my high flow cat and headers today and i have a raspy/burbling sound too. But as stated above once i drove it long enough to get it warmed up it went away. I was really worried but after reading above i am not anymore. BTW when its warmed up it sounds really good.
PSN ID: Phatchance249
Tuesday, January 03, 2006 6:40 AM
had the same problem when I installed mine way back...the factory cat muffles a ton of sound...
_
2002 LS Sport coupe
Tuesday, January 03, 2006 10:13 PM
viper
you say for cat you got 94035
I was under the impression 94036 was 2.5 and "35" was 2.25
Is this incorrect?
Save a Tranny, Roll-on
15.3@88m.p.h.(I/E)
15.2@94m.p.h.(S/C'd)
15.5@89m.p.h.(Stock GTP)
Wednesday, January 04, 2006 4:18 PM
blwnz24, thats exactly correct. but for personal reasons, i did my full setup in 2.25, rather than the "optimal" 2.5
