EGR Simulator installation - Performance Forum
Monday, December 26, 2005 3:30 PM
I bought the ZZ Performance EGR simulator the other day to fix my EGR check engine light. The simulator has a box with a 4-prong plug and a white and green wire. I am supposing the white and green wires splice into the map sensor wires. What plugs into the other end?
Re: EGR Simulator installation
Monday, December 26, 2005 5:33 PM
The plug that would plug into you egr now plugs into the sim.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Monday, December 26, 2005 5:36 PM
yes heres a diagram if you need help wireing
egr wire diagram
View my MySpace
Monday, December 26, 2005 7:23 PM
Did you guys just put a blank plate over where the egr goes? If i don't put on a sim. my check engine light will come on right? Does not using the egr hurt anything. Changing to the ho intake is a PIA. I never gave the egr a thought till tonight when i went to put in my ho intake.
2nd Place is the first loser
Monday, December 26, 2005 10:40 PM
so it's best to use heat shrink on the connections to the EGR sim. and in case the EGR sim does cause the car to run like @!#$ and I wish to take it off... there is enough slack to reconnect what i cut out?
