For everyone who has done this swap (2.3L throttle body on 2200) is there anything I should know ... ?
any problems I may run into ?
any tips ?
and most importantly... does it really do anything ?
I got a 2.3L TB for free .... and I'm fat and lazy ... so I'm just wondering if it's even worth doing ... as opposed to getting one from RSM or JBP
<A HREF="javascript:openImage('/members/image/so0loud0it0hz/personal_pic.gif/','200','500');"><img src="/registry/so0loud0it0hz/thumbnail_personal_pic.gif" width=250></A>
YES its worth doing. I love mine, though im getting another one, mine is cracked.
Event did a write up some time ago. Do a search.
That's good to know, was it hard to do ??
did you use the IAC from the 2.3 ? or swap it with the one from the orig ? the tb I have is in good shape ... structurally .. but I'm sure it was in a car that detonated or something ... there's some prehistoric- fossil like deposits in spots .. so I'm a little weary about using the IAC thats with the 2.3 tb
you probably have to use the IAC from the 2200, because of the difference between OBD1 and OBDII.
when i first did this on my 2200 i used the same IAC from the TB but i swapped out the TPS from my newer TB from the 2200, just because I knew it would work right, just clean it up real good and have fun.
get some brake cleaner and go to town on the TB before it goes in !
Lee
JDM Civic Hatch
you dont have to change ANYTHING besides the rotor arm....
its all in the writeup.
had a hell of a time with mine, it leaked, then got that under control, then the car got stuck at 4k rpms... i think it was a sensor related issue.
i've got a hybrid 2200/2.3L TB that i'm willing to sell, it bolts up and everything, if anybody wants it $150 CAD obo
1998 Chevrolet Cavalier
5-spd
only reason i re-used the old TPS from my 2200 was because i did not know the condition of the one already on the TB and only wanted it off once, but the write-up Event did was key to me even doing it
