hey guys my name is travis i have a 92 z24 with a 3400SFI this is whats going on i keep frying my coil pack modual for some reason i changed it one day and it ran fine then i tryed to start it and it wouldnt start i scanned it and it came up a code 42 so i changed the modual again and AGAIN it died this time after about 10 sec, so i changed it again started and died everytime it starts it dies so i try to start it and it wont unless i changed the modual anyone have any ideas, im thinking a short ,wireing is not my strong point , o and another thing my RPMs go nuts when it runs for 10 sec, there is also a relay on my firewall that say ABS then i think its a 6 in roman numerals it keeps tickin constantly when i get in the car ( its not running ignition is on) the RMPs are a at zero ( where it should be) and every tick it jumps up and down up and down if someone can help me out that would be great
Thanks Travis
have you replaced the crank sensor ??
they usually go out also , and cause no start issues
this shoulda been in maintenance also
can a crank sensor cause it to fry coil pack moduals???
3400sfi wrote:can a crank sensor cause it to fry coil pack moduals???
the crank angle sensor is the initial stages of ignition, then the ICM tells the coils to fire basically
basicly if you have a problem from time to time , the crank sensor can work and not work
which in turn causes the ign module not to work also
which means the car doesnt start
the tech i used to work under when i was learning , he told the 2.8 and 3.1's have alot of problems with the crank and ign modules and he said if you replace 1 you replace the other , it will save alot of people coming back again
[quote=97cavie24ls(JDM&00s/c sedans™)]
always loved those kind of Tech's........ just throw parts at it, till it runs
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
i heard they had problems with moisture bu dont quote me on that...
I Drank 750 Bottles Of Mountain Dew For A XBOX 360.... AND ALL I GOT WAS THIS STUPID HAT.
ok im gonna go pick one up tonight change that and the modual thanks for all your help
Travis
well i changed it, and again it died i got another modual changed it too tighted some wires and it still keep frying the modual im getting really sick of this and i dont know what else to do
Have you asked at all on 60degv6.com? Or domesticcrew? You might even be able to search both the sites and find some info.
im trying google right now getting close but yah i'll try that too thanks man
so it ended up being the computer im gonna put a day perment on it , see if its to good to be true
thanks for ur guys's input
