Update! 2.4L Pulley Design - Performance Forum
Wednesday, November 30, 2005 7:16 AM
Well if anyone remembers, I am designing Pulleys for a 2.4L engine for my senior project......
Old, Old Post
Well I am almost finished with the preliminary design for the crank, alternator, tensioner pulleys. I am going with all pulleys CNC machined from T6-6061 aluminum. They will also be A4 hard coated clear. The crank pulley will be slightly under-driven. Not 100% sure on how much yet. I want the alternator to not loose more than 15% energy output. So there will be as little as possible charging issues if any. The alternator is a stock size, with a lightweight design. Also the tensioner pulley will be stock size, with a lightweight design. I will also be bypassing the A/C compressor completely or A/C bypass pulley completely. "Which ever you may have."
There are three major things that I'm not sure of still, is the crank pulley a press fit, and by how much? Also I have seen many after-market pulleys with no key-ways, why is that? I believe it needs to be there...............Also does any of you guys/gals after-market crank pulleys have the knurling on the back or is it left off?
Any input on anything would be appreciated.
Re: Update! 2.4L Pulley Design
Wednesday, November 30, 2005 7:37 AM
the key way needs to be there , and the pulley is a press fit
the rsm pulley ive seen was finished on both sides
Wednesday, November 30, 2005 7:59 AM
Niice
Wednesday, November 30, 2005 8:52 AM
Make sure you use the industry standard for the groove design. I don't have the specs handy. Otherwise the belt will slip due to lack of contact.
Wednesday, November 30, 2005 9:12 AM
Well I'm currently looking into that.
i have found THREE standards that all say something different.
They have different angles 38, 40, and 42 degrees. And all other dimensions are a little off here and there.
Wednesday, November 30, 2005 8:58 PM
I sent you the stock pulleys glad to see your having good progress. Are you just making prototypes? or do you plan on manufacturing these pulleys?
Thursday, December 01, 2005 3:17 AM
Coldairintake takes for the pulleys again!
Also found the specification the the grooves in the back of a Gates catalog.
Well for now I need to make prototypes, but before I do that I need to get a dyno done to get a baseline. Then after I install my pulleys I will get another dyno done to see the difference in horsepower.
What a concept....Laughs at self...
Then probably by summer I will have everything lined up to sell them as sets. I have no real firm pricing yet, but I want to try and keep the total at most under $300.
Tuesday, December 06, 2005 7:39 AM
Gates catalog has all specifications, I needed.
Also side note messed up on Price I want to keep them under $250 a set, if possible.
Tuesday, December 06, 2005 4:21 PM
Still though, lightened factory sized is just as good.
That and lightened alt. will be the safest route for folks.
Don't have to worry about finding the correct belt size and all that jazz.
-M
Tuesday, December 06, 2005 5:14 PM
were you going to do a larger tensioner pulley ?
i need to find someone that will make a larger tnsioner pulley and idler pulley , so i can swap the s/c pulley for a smaller 1
Wednesday, December 07, 2005 3:25 AM
[quote=97cavie24ls(JDM&00s/c sedans™)]were you going to do a larger tensioner pulley ?
I need to find someone that will make a larger tnsioner pulley and idler pulley , so i can swap the s/c pulley for a smaller 1
Yeah I could probably, wouldn't be to hard at all. What size are you thinking?
That would be the easiest pulley. Maybe I will do that over winter break.
Maybe later down the road I will do a larger crank pulley. Just got to finish some more of my project.
Wednesday, December 07, 2005 7:39 AM
i was thinking like 1/4" to 1/2 larger in diameter
Wednesday, December 14, 2005 3:45 AM
97cavie24ls(JDM&00s/c sedans™) would you like me to just draw the part or make the part?
I will be wrapping up 90% of my pulley design work by mid Jan.
Wednesday, December 14, 2005 7:47 AM
id really like to have a pulley in hand , so what which ever works to get a final product
ive got a extra tensioner some where , if your in need of 1 for the pulley on it
ill have to see if i can get the idler wheel for the gm s/c kit , ill prob have to buy 1 from gm , but for a larger pulley and lighter , im up for it
Wednesday, December 14, 2005 9:40 AM
Do you have a plastic or metal tensioner pulley?
Wednesday, December 14, 2005 10:05 AM
i have 1 of each at home , i forget which 1 the 00-02 is
ill have to look at home , unless anyone knows off the top of their head
im thinking the 00-02 is the plastic though
Wednesday, December 14, 2005 11:39 AM
The UR pulley had the keyway, but slipped right on. No pressing required. Easy to slide on and off, just bolt up.
I would LOVE a lightweight replica of the stock 2.4L pulley. Stock size, just aluminum! As long as it was around $100 or so I'd buy it
Thursday, December 15, 2005 4:43 AM
Is the plastic and Metal one the exact same bolt hole and outside diameter? I beielve they are just would like to make sure.
Yeah lenko crank pulley will be stock size.
I don't think 100 is out of the price range but still have no firm qoutes to go buy.
Thursday, December 15, 2005 8:34 AM
ill look for my tensioner pullies on saturday , itll be the first chance i get
so if some one can do it before me feel free to give us the info
Thursday, December 22, 2005 12:36 PM
[quote=97cavie24ls(JDM&00s/c sedans™)]ill look for my tensioner pullies on saturday , itll be the first chance i get so if some one can do it before me feel free to give us the info
Well.....
Thursday, December 22, 2005 1:10 PM
sorry i got blank minded , LOL
my 00 has the plastic pulley , also from looking at it , about 1/8" bigger is the most the size could increase , since the tensioner , and s/c idler sit right accross from each other
here is a link to the pic of them
http://www.azjbo.org/forum/garage_img.php?pic_id=130
Friday, December 23, 2005 11:55 AM
Thanks man for the info. I going to pick up another METAL tensioner pulley probably today. Hopefully I will them all designed before the first of the year!
Friday, December 23, 2005 10:27 PM
sweet
Saturday, December 24, 2005 1:00 AM
Any clue if your goignt o be helpign the 2200 guys?? ill buy one in a second!!..phil
Saturday, December 24, 2005 4:35 PM
ya I'd buy the alt pulley for sure.......... I don't have a sound system ....... lets do it !!!!!1
Lee
JDM Civic Hatch
