upper motor mount install help - Performance Forum
Saturday, November 26, 2005 2:55 PM
i have got the insert and mount in place but can't for the life of me get the two bolts back in place. I have tried to pull on the motor but I can't get them back in place. install goin on two hours now, any help would be nice.
than ks
hugs and hand pounds, peace
Re: upper motor mount install help
Saturday, November 26, 2005 3:18 PM
If you are running a 2.4, jack up the motor itself and you will have no issues getting it in. Just make sure you place the jack on the meaty sump of the pan. I havent cracked one doin this. I can have the whole timing cover off in just over an hour, it works.
2002 Z28: Slp coldair Pac, Corsa Catback, 3200 stall
Saturday, November 26, 2005 4:27 PM
i finally got it. I had to go buy two new bolts, i put one of the new bolts down tight then put the stock bolt in the other whole repeated with other side and got both stock bolts back in and returned the bolts that I bought, tomorrow will be lower mount.thanks for the help man
