2.2 to 2.4, does it have to be same years? - Performance Forum
Tuesday, November 08, 2005 10:54 AM
i currently have a 98 2200 ohv with 4 speed auto. im lookin for a 2.4 for it, but im wondering if it has to be out of a 98. i know that it should be straight forward if i keep the years the same, but if i say get a new 2.4 would there be any surprised that id encounter? thanx
Re: 2.2 to 2.4, does it have to be same years?
Tuesday, November 08, 2005 10:56 AM
it shouldnt matter what year, cause you will have to get the ecu for any of them.
10.5 second 1/8mile
est hp=130
est tq=135
Tuesday, November 08, 2005 10:59 AM
ok, so say i find a donor car. it should just be a matter of pullin the motor with the wiring harness to the firwall and the ecu? thats it? could i use my current tranny, or should i use the one with the new motor? and are the mounts the same?
Tuesday, November 08, 2005 9:13 PM
can anyone give me some info?
Tuesday, November 08, 2005 10:50 PM
All you need is to make sure you get he correct generation 98-02 i believe
2002 Cavalier ECOTEC 5SP (14.2s @ 35C)
Tuesday, November 08, 2005 10:59 PM
as long as you run that year PCM you will be just fine.
Wednesday, November 09, 2005 12:06 AM
If you want to plug-and-play it (as you mention, just the engine bay harness) you should stick with similar years... in your case, 96 to 98 2.4L's.
99+ 2.4L's have some minor changes... not hard to swap in, but not "plug and play". You'd have to make some wiring changes. Even more so if you use a 2000 PCM... there's a LOT that changed in the pins between 99 and 00.
Wednesday, November 09, 2005 2:18 PM
ok....thanx guys
