i have the specs on my reground cam for my 2200.can anyone tell me what my rpm range would be for power.i was told to get my limiter removed for full potenial.and also my map sensor is all screwed up.
duration @.50valve lift intake,224,490,exhaust224,490
lobe seperation 112
lobe center intake 106,exhaust 118
you don't need your limiter removed. it's there for a reason. you're going to make a LOT of power up top. Judging by that cam spec you'll have decent low end torque but you will really start to gain thrust around 3000
Also remember, your camshaft is in the middle of your motor. If you're going to regulate more exhaust flow and intake flow, you should really work your cylinder head to bring in more. If you do, you wouldn't be dissapointed.
Patriot-Performance makes a P & P head for the 2200s and you can buy all the goodies that you need for the cylinder head (springs, rockers, retainers, pushrods etc) from Jbody Performance.
www.jbodyperformance.com
www.patriot-performance.com
Good Luck.
i had the motor completely rebuilt about less than 3 months ago,p&p is done well in depth.the only real concern is my map sensor it is way out of wack.it floods really bad alll the time.my mechanic says that the computer is not picking up the cam.the map is running a high voltage all the time
Yup Jimmy's got a good point. You can either go with an SAFC or other piggyback.... OR you can go through JBP to get a reflash done.
