Problems Installing Arospeed eco header... - Performance Forum
Wednesday, October 19, 2005 3:48 PM
Ok, I finnaly got it finished, With a couple problems...
1. How to you tighten the bolts on the top of the header, the ones that bolt the header to the head(on the top)....A wrench wont fit and i cant use any socket because of the pipe in the way..
2. It is hitting my crossmember when I will backup or start going forward, basically anytime there is pull on it..
Re: Problems Installing Arospeed eco header...
Wednesday, October 19, 2005 6:13 PM
Performance mounts for my car stopped all engine/tranny movement. Should stop the hitting on the crossmember. No idea on the bolts. Maybe a ratchet wrench?
My Cardomain Page<--Updated 9/19/05
Wednesday, October 19, 2005 6:47 PM
You might need a ratchet wrench to get to them.
15.71 @ 87.9mph 9-17-05
Wednesday, October 19, 2005 10:20 PM
so do you guys think mounts should solve this? I'm thinking a lower mount would probably help the most..I need it welded too, It sounds like i'm boosted
Wednesday, October 19, 2005 10:22 PM
as others have said, engine mounts should solve the movement problem. it'll also prevent the piping from cracking once it's welded up.
Friday, October 21, 2005 6:34 AM
I have no problems with mine hitting anything, I have both mounts..
Friday, October 21, 2005 9:34 AM
the stock eco upper mount is a piece of junk and is usually torn
so its best to upgrade it first , even though it is the most expensive 1
