01 z24, quad 4 to ecotec?? need some help - Performance Forum
Thursday, October 20, 2005 4:46 PM
well i think my quad is going down.. so i want an eco to swap it but i just need to know what i am going to need for the swap? and biggest question will it fit my tranny? i searced and found nothing so please help me out. its covered by warranty so i am wondering if the shop does decide to replace the engine will they put an eco in?
r.i.p rotary
Re: 01 z24, quad 4 to ecotec?? need some help
Thursday, October 20, 2005 5:19 PM
there are lots of posts....you just have to search all forums. I was in the same boat.
if you go auto to auto....its a pretty easy swap.....but if you go to manual you have to weld in 2 mounts
Thursday, October 20, 2005 6:40 PM
give me an idea on key words i tryied everything, and its a manual.
r.i.p rotary
Thursday, October 20, 2005 6:50 PM
Transmission will not fit the Eco, and no, it will not be replaced with an Eco. Also, your engine isn't a Quad4. They won't replace it with an Eco because of how much it would cost (replace tranny, bcm, ecu, etc).
Thursday, October 20, 2005 8:08 PM
no they wont put an eco in it.....they will put what was in it.
in order to install an eco you have to basically redo most of the car
Thursday, October 20, 2005 8:18 PM
yeah maybe i was hoping for the best.. maybe i will just stick with my new 2.4
r.i.p rotary
Thursday, October 20, 2005 9:35 PM
HO SWAP!!!!!
Friday, October 21, 2005 7:42 AM
[quote=¤§Fallen Angel§¤]HO SWAP!!!!!
you got it
Friday, October 21, 2005 9:29 AM
to swap a eco into your 01 Z24
you need the motor and trans , and the engine harness for the eco , pcm and the bcm
if you keep the trans swap 5spd to 5spd , or auto to auto itll be a direct easy swap
Friday, October 21, 2005 10:13 AM
HO SWAP!!!!
nuff said
"Freedom 'ought to have its limits"-George W. Bush may 31 1999 (who voted for this idiot?)
Friday, October 21, 2005 12:58 PM
BCM is not needed, ha, tells you how much people here know about this swap, and does anyone wanna question me?? lol jk
He has a 2001 guys, and I don't know if that makes much difference to you all, but it makes Eco swap in his car possible from like 4 days to 1 day. lol
Best time:"""11.946""" @ 114.73 mph @17psi 1.83--60"
11 second daily driver!!!!
Race Related 727-561-9440
Shop of choice for your 11 second J body!
Also, built bottom end and or top end LSJ and L61's available.
13's ----12's ----11's ----10's
Friday, October 21, 2005 1:12 PM
ive swapped pcm's , and never had the car start
only time i was able to get 1 to start , was with the matching bcm
yes i followed the 00-05 theft relearn procedure
Friday, October 21, 2005 1:51 PM
what i was thinking about the swap would be direct bolt. just because the 01's came with eco's too that is all, the eco is a far better motor than the 2.4, 2.3 though it may have little girly rods but that is easily fixed.. just looking at potential and after boosting my friends 03 and seeing the results of a @!#$ty azz setup.. its all we could afford.. got him a 14.0 on 8psi with a turbo that a lawn mower would spool... but i really have not had much expeirance with the 2.4, i ran a 16.5 on my second run ever in a fwd car.. and i have no tach in my car, it was stock and i was actually shifting around 5500. so 16.2 would have been an easy goal... sorry for rambling but you guys understand right? i am just juggling
r.i.p rotary
Friday, October 21, 2005 2:57 PM
Ecotec motor didn't come on the J's until late 2002 so you are wrong there, there is no Eco available in 2001.
I would be a very easy swap unless your tranny is auto then it would be a little harder if you are going manual but you could get Eco automatic. too.
I have done 3 swaps and each time the car would start following my Theft bypass, including mine. All by far mismatching BCM's.
I guess it is just luck thing.
Friday, October 21, 2005 4:30 PM
SunCavi_L61T3/T04E wrote:Ecotec motor didn't come on the J's until late 2002 so you are wrong there, there is no Eco available in 2001.
He is correct. I have done 2 ecotec swaps. A 2000+ car is a easy swap depending on the tranny you want to go with. motor, tranny, ECU, if you can get the BCM, but not a have to. Engine bay wiring.
Friday, October 21, 2005 4:36 PM
so by simple swap please fill me in? would i be using my trany? its 5spd
r.i.p rotary
Friday, October 21, 2005 5:24 PM
240 your azz!!! wrote:so by simple swap please fill me in? would i be using my trany? its 5spd
No the 2.4 tranny will not bolt to a Ecotec. Re read my post I told you what you need. I say easy because I have done 2 pre 2000 J/ We had to strip everything out of them, re-wire the whole car, fuel tanks, fuel lines, weld in the mounts put interior back together. Lots of work, compared to just dropping in a motor for your car, engine bay wiring, tranny.
Friday, October 21, 2005 5:31 PM
ive been trying to figure this out for days i have a 99 z and
i want to swap out my ecm from 99 to a 00 and get it reflashed but i need to know if i need the bcm? can someone elaborate on the theft bypass and how to do this please because i cant find anything
