Do i still need to put a gasket on with the converson flange or is the flange ok by itself, its made out of Phenolic if that matters.
Thanks
i put the 2.3 gasket on
96 cavy z24
which side did u put it on?
a 2.3 gasket is needed or some good high temp silicone. If you use the gasket make sure to elongate and slot the same holes on the gaset as the manifold.
do u put the gasket on the head side or the manifold side of the flange?
I wanted to know the same thing since im doing this too.
Well for me,
I took a few 2.3L gaskets sets from advance auto parts. and 'fabbed' my own.
Common knowledge about the 'B' shape of the 2.4L side.
So basically I got a set of dikes (the hand tool kind) and snipped and snipped until I had the gasket I needed.
I would show a pic, but i just sold the mani and am shipping if off Friday,
-M
put the gasket on both sides of the flange........ I used some of the 'make your own gasket' stuff from Advanced or Auto Zone..... gasket paper.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
I got some of the make your own gasket and i will make one for each side of the flange since it would help seal both sides. thanks for all the replies.
