Can somebody tell me why my car is slower with my intake off? I have the HO Mani and I took my intake off at the track hoping maybe i could get a better time, but it actually slowed it down really bad.....my 3rd was total crap, does anyone know?
NEW SIG COMING SOON FOR 07'!!!
thas wierd......... i took my rubber hose off when i tokk it to the trac......
wait...........What did you do with your sensor?
wait for it... wait for it... NOW GO!! ---> '02 LS Sport <---
Yahoo IM : buzz122 AIM : buzz122cav
...loss of torque due to velocity issue? maybe turbulent air entering the t.b.? ask event, though i havent seen him post in a few days. i really dont know, but i have noticed the same thing. it will kill your powerband.
...don't hate!.. respect people that have talent, even if it is in something you don't like or understand.
I'm gonna ask another question.....that sortra relates, but not trying to steal your post........
This hapens sometimes when i'm coming out of my parking lot, or starting to accelerate onto the roadway, and i'm ready to go, go, go, and i'll move like 3 feet, and then it feels like the motor almost dies, like theres lack of fuel, or something. I get a jolt forward, and then right away get pushed back in my seat...... and then i get on my way........
I don't think its the way i drive, cuz the clutch is fine, and theres no rattlingf from a jerky clutch.
could it be that theres a lack of fuel in the line, and it gets cut off.... or somesensor thinks theres too much. It's gotta do aomething with the motor.
it is lose of velocity, put it back on
Sorry...
You have been banned from posting on this site as of 2005-09-21
00:33:32. This ban will expire 2005-09-28 00:33:32 Pacific Time.
Reason: Comments over the top regarding Jordan Kruger and other members in Versus. Also, if you have a problem with a member e-mailing you, do not bring it into the forums.
If you believe this to be in error, please contact us.
You will only gain power but removing your intake. I have witnessed it first hand on 3 different cars in a row on a dyno.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
if he totally removed his intake the iat sensor is probably so confused it pours down 5x times gas it should.
15.574 @ 89 mph stock
Skilz10179 wrote:You will only gain power but removing your intake. I have witnessed it first hand on 3 different cars in a row on a dyno.
Yes, they probably did gain power, but what happend to thier low end torque?
W/O the intake there is very little air velocity, which kills the low end torque.
ive run open TB on the track quite a few times and left my IAT still hooked up just tied it up, and i didnt lose any maybe gained .1 in the 1/4
The one, the only, ME.
MadJack wrote:Skilz10179 wrote:You will only gain power but removing your intake. I have witnessed it first hand on 3 different cars in a row on a dyno.
This is actual dyno graph of a 100% stock 2002 Cavalier 2.2L Ecotec. 100% stock (dotted line) vs 100% stock with the intake removed from the throttle body (solid line).
HP and torque gains over 95% on the entire rpm range
Enjoy.
But the turbulence of the air would not be a factor if the car was stationary on the dyno as opposed to speeding down the 1/4 mile.
J
your going to have turbulance no matter what kinda of intake setup you have cause the throttle plate is there you can have it twriling as best and fastest you can through the intake tract but once that airflow hits the throttle plate the idea of trwirling and speed is gone
check your spark plugs I had a problem with my car feeling like it wanted to die and i changed my plugs and it went away. im thinkin you gap may of changed or there due for a change. Ive made it a habit to regap mine every time i change my oil so i havent had a problem since then
Z Styling wrote:But the turbulence of the air would not be a factor if the car was stationary on the dyno as opposed to speeding down the 1/4 mile.
There is probably just as much if not more turbulance with the open throttle body on the dyno with the hood open and the dyno fan blowing on it as there would be with the hood closed driving.
