2.3l performance parts - Performance Forum
Friday, October 07, 2005 2:23 AM
Im looking for some parts for the 95 2.3l. 4to1 header,rebuild kits,a/c delete belt pullys,bearings things of that sort but ive been searching differnt engine site to no aval and was wondering if anyone could help me out or tell me if some of the 2.4l parts are interchangeable like the ac delete pulley kit .thanks nick
Re: 2.3l performance parts
Friday, October 07, 2005 2:26 AM
Are you looking for aftermarket or stock parts?
Friday, October 07, 2005 2:28 AM
aftermarket
Friday, October 07, 2005 2:30 AM
and stock if need be for the rebuild items
Friday, October 07, 2005 2:53 AM
Car Customs - 2.3 Parts
I believe, as far as bottom end parts, you can use the 2.4 motor parts.
For OEM parts...check out www.car-parts.com for a local junk yard near you.
Friday, October 07, 2005 3:15 AM
Performance parts.
Cams:
Engle Cams www.englecams.com
CompCams camhelp@compcams.com
Crane E-mail them ONLY customerservice@cranecams.com
Adjustable Cam Sprockets:
GMRocketparts +/- 4 dregree PN# 22551543 www.gmpartsdirect.com
Heads:
TRS JoshGooding@The-Race-Shop.com
GSR scott@quad4forums.com
Crank, Block, Rods:
Eagle 2.4 H-Beam PN# CRS5710C3D
Eagle 2.3 H-beam PN# CRS5806C3D www.cnc-motorsports.com
GM Rocketparts Titanium rods PN# 22551571 www.gmpartsdirect.com
GM Rocketparts heavy duty forged steel crank PN# 22551525 www.gmpartsdirect.com
Headers:
no one makes them.
You would have to have one custom made. Or the Stock 89-92 HO
Piece flows best. however, some of us are working on changing the manifold flange on 2.4 headers to make it work on the 2.3.
Chips, ECM/ECU (95) :
Superchips www.superchips.com
GM (HO-W41) www.gmpartsdirect.com
Jet www.jetchips.com
S-AFC www.apexi.com
Flywheels
Fidanza www.aluminumflywheels.com
Valve Springs:
Crane Part # CRN-99846-16 www.summitracing.com
Lifters:
Melling 2.3L JB-2236
Melling 95 2.3L 96+ 2.4L JB-6051 www.melling.com
Valves/Valve Guides:
www.sivalves.com
Pistons
Ross www.rosspistons.com
Wiseco www.wiseco.com
JE Piston www.jepistons.com
Copper headgaskets:
SCE stock thickness Pn# 91704
avail in .032,.043,.050,.062,.080, and .093 thicknesses. (.043 stock) www.scegaskets.com
Clevitte Rod Bearings PN# - CB1388P
Clevitte Main Bearings PN# - MS1703P
ARP Head Stud Kit PN# - 281-4301
ARP Main Stud Kit PN# - 281-5401
no you can'T use the 2.4 parts for the bottom end. You can use the crank and rods if you modify the block to stroke it but it's not an easy job.
Gilles
2.3 Ho
Friday, October 07, 2005 3:42 AM
Mfk-223 wrote:no you can'T use the 2.4 parts for the bottom end. You can use the crank and rods if you modify the block to stroke it but it's not an easy job.
Once again, you are the master of the 2.3...
Yeah, I wasn't sure. Usually if I'm not sure I put "I believe" or "I think" in the sentence. Once, again, thank you for the correction.
Friday, October 07, 2005 3:48 AM
Knew you were pretty knowledgeable about the 2.3L for some reason.
Holy info batman.
Any love for the 2.4L?
-M
Friday, October 07, 2005 12:28 PM
nick99z24 wrote:Im looking for some parts for the 95 2.3l. 4to1 header,rebuild kits,a/c delete belt pullys,bearings things of that sort but ive been searching differnt engine site to no aval and was wondering if anyone could help me out or tell me if some of the 2.4l parts are interchangeable like the ac delete pulley kit .thanks nick
Try www.the-race-shop.com for headers (dont know if they have them made for the J yet) GM sells a AC delete pulley, the part number might be on this site somewhere, it is also on www.quad4forums.com
Nothing is really worth interchanging with the 2.4L besides maybe the GM supercharger kit you can buy for the 2.4L
Click the banner to enter the best Quad4 & Twin Cam site on the internet.
Friday, October 07, 2005 3:44 PM
nope,not yet available...me and josh are currently working to try and fit the current version into a jbody..well know after my engine goes in...if it doesnt hell design one to fit the Js
as far as the delete pulley i heard GM stopped selling them
"Freedom 'ought to have its limits"-George W. Bush may 31 1999 (who voted for this idiot?)
Friday, October 07, 2005 8:49 PM
2.3 AC delete is part #22533199, vs the 2.4 one being 24574519. They mount different to the block so dont try using the 2.4 one. Mantapart has the adj cam gears, dont think they were ever on the site but call Tim there & ask him.
Saturday, October 08, 2005 8:05 AM
i have a flywheel,clutch,cam gears already im looking to run a 50 shot setup on the car so what do you guys think ill need for the motor?
