just finished taking the interior out, when to move the car, the car will start and then die few seconds later, what the hell did i do, i need help im not sure what the @!#$ i did. thanks
What exactly did you remove? what in the dash? anything electrical that you didn't reconnect?
what year is the car and did you remove the cluster? also will it do this over and over? if this was an underhood problem i would sugest chcking the coolant temp sensor. that can cause that problem. i havent tripped the theftlock system on my car so i cant be sure but i have also heard that removing the cluster can trip it casuing the car to start then die and not restart w/o being reset. (only on some years unsure of what ones)
99 Turbo Sunfire GT | Ram 2500 | International Rollback | Mr Hanky the Suburban
yes i took absoultly everything out, the only thing in the car is the steering wheel. nothing has been hooked up as it is not finished yet, the interior, 98 2.4 cavi i never thought about the cluster and the anti theft.
thats proably the problem.
