DC Sports Ecotec Header - Performance Forum
Thursday, September 15, 2005 12:47 PM
What is the word on this header, I have been interested in getting one for sometime, but I have read somethings on here that say it doesn't come with the b pipe. I would just like to know what header is most recommended for performance as well as cost, because I would love to do DC Header and Exhaust (which isn't out yet) to match my AEM Intake. I am open to any suggestions what-so-ever.
Re: DC Sports Ecotec Header
Thursday, September 15, 2005 1:07 PM
not worth the cost get the pacesetter coated
Thursday, September 15, 2005 1:18 PM
yea... stay away from that header. go with the PS only if coated.
Thursday, September 15, 2005 3:06 PM
It will connect to the stock 2nd lower flange. The one that is 4 bolts with the flex joint. For the best bang for the buck i would go with the pacesetter. We have a couple painted in stock and ceramic should be in stock soon.
Click the sig.
-Aaron
www.TurboTechRacing.com
Thursday, September 15, 2005 5:19 PM
Would I want to go with the Pacesetter Armor Coated Header then, is that the correct coating you are mentioning above?
Thursday, September 15, 2005 5:29 PM
Yes correct. Most comparable to the DC Sports one. Just i think a better overall design.
-Aaron
Thursday, September 15, 2005 6:35 PM
Okay thanks for the input guys, looks like I will definitely be going with the Pacesetter Armor coated headers from what you all have had to say and what I have seen in the past. Just one last thing does anyone know any of the performance numbers for these?
Thursday, September 15, 2005 8:02 PM
Don't know the numbers but you will notice a big improvement on the top end. make sure you get a high flow cat and try to get some shop to make a custom piece that will bolt on to the resenator, this way if you ever need to put your original header back on for any reason it will be a snap..good luck!!
Thursday, September 15, 2005 8:41 PM
Rough guess top end 5-8 hp and 6-8 lb/ft torque
-Aaron
Thursday, September 15, 2005 9:29 PM
Turbo Tech Racing wrote:Rough guess top end 5-8 hp and 6-8 lb ft torque
Yea my guess as well. But it's not just the power aspect. You are looking at a less restrictive exhaust to gain you more potential for other things down the line.
Monday, September 19, 2005 12:34 PM
from what I understand tho the pacesetter is a horrid install, the DC Sports is supposed to be a nice clean bolt-on? So you'd save in installation costs.
any opinions?
-Chris
Monday, September 19, 2005 12:39 PM
I've done an ECO and a 2.4L PS header install and neither was a "horrid" install.
Monday, September 19, 2005 3:45 PM
the dc is easier
cause its a manifold replacement
but the pacesetter isnt hard unless you have a auto , and the reason its hard is you have to wiggle it alittle more cause of the room the auto eats up under the manifold
Monday, September 19, 2005 10:36 PM
So basically the pacesetter is cheaper, but much harder to install. I do have a manual transmission though. The DC is easier to install and goes much smoother...and I have read that gains with that are 10-12 hp. I don't know if any of you have them, but if I could get a comparison that would be great.
Monday, September 19, 2005 11:01 PM
Anyone have pics of the DC header?
-M
Monday, September 19, 2005 11:20 PM
ill have pics soon of another dc sport header
i can try to take pics of the g/fs header
you might try a search on ebay for a eco header , there was 1 from a wrecking yard that was on ebay recently
not sure where you heard 10-12 hp from , that is high for a 4cyl
Tuesday, September 20, 2005 8:08 AM
so they are both a direct bolt on, no cutting, welding etc?
-Chris
Tuesday, September 20, 2005 9:47 AM
dc's is the only bolt on
all other headers from all the other companies , require cutting and welding
Tuesday, September 20, 2005 12:37 PM
It appears as if my thoughts have changed and I will be going with the DC Header, although this purchase my not be for a while. The 10-12 hp came from the gravana site in the part description. Anyhow thanks for the input and some pics would be great!
Tuesday, September 20, 2005 12:47 PM
You dont have to cut or weld the Weapon R header I know cuz I have it
Tuesday, September 20, 2005 12:54 PM
you do to bolt it up to the existing exhaust... just like with the pacesetter and the rksport.
there's no flange pre cat for you to just bolt it up to.
Tuesday, September 20, 2005 1:09 PM
i can take a pic of my dc header if u want...might not be great quality cuz i'll have to take it with my phone...and i might need someone to host it for me, or i can just email it to u
Tuesday, September 20, 2005 1:12 PM
www.imageshack.us for image hosting.
