Anyone know where i can pick up a set of new main studs for my 95-97 OHV 2.2?
Stock or Aftermarket?
I'm sure you can find some ARP studs to use. I just don't know the measurements.
Spotabee Racing wrote:I'm sure you can find some ARP studs to use. I just don't know the measurements.
Well from my understandment, the studs are connected to the rockers on the OHVs, so if he wants to replace the stud, he has to replace the rocker as well.
uh nope. the stud goes through the rocker. that's what the pivot balls are for.
^^ the 2200 has the studs attached to the rockers
maybe the 95-97 OHV is different with its rocker set up
...however I don't think rocker studs are main studs
by saying 'main studs' I'd assume the original poster is referring to crankshaft related items
clear up what you're looking for dave....
actually, by main studs i meant the hardware to put into the block to mount everything back on it,
ok i figured crankshaft related, not rocker related. i didn't know that about the 2200 rockers. i just know how mine are.
the rockers go on rocker studs, unrelated.
what side of the block? head studs can be found at jtuners.com.
Supposedly they may be trying for some main studs (hold on crankshaft mains) as well.
<img src=http://hometown.aol.com/yogiandbooboo7/images/french.jpg>
